Readylift 5" rear block install update - got vibes - kinda long read
Morning all,
Just a quick update after installing my 5" readylift rear blocks - had a chance to drive the truck a few miles, and now I have a vibration. Hopefully this information helps someone else
The 5" readylift block (the only one they offer) is tapered roughly 4 degrees.
When installed on my 156" wheelbase crewcab shortbox, it rotates the pinion up so it is almost aligned with the driveshaft. I think this is where my vibration is coming from - the pinion needs to be parallel to the carrier bearing (or transfer case output) to keep the u-joint angles equal.
I contacted Readylift and they themselves said this block was designed for this particular vehicle, however some require a flat block or a carrier bearing spacer. Or another fix would be to add a 2.5 degree shim to the blocks.
Spacing the carrier bearing down would help equal out the u-joint angles, but my pinion still wouldn't be parallel to the t-case (or carrier bearing - the carrier bearing is essentially an extension of the t-case output). I think that is a band-aid fix in my particular situation.
I guess the bottom line is I think I should have gone with a flat block (as per everyone's recommendations on here - duh ). Now I'll either get a 2.5 degree wedge shim for the leaf springs (per what Readylift said) or swap out the tapered blocks for flat ones.
Chalk this up to experience I guess .
I'll let you know how it goes.
Thanks,
Pat
Thanks,
Pat
Most shims can bolt to the existing leaf spring pack, so they become part of the leaf pack, to reduce the chance of spitting one out. Still, I agree with what you said, I'm not crazy about stacking a shim in there.
I'll figger something out
Thanks!
Pat
Sorry for the confusion,
Pat
BUT....the more I think about it, if I can shim the carrier bearing and correct the u-joint angles, then I'll leave the pinion alone. Assuming of course the pinion isn't rotated so far that I starve the front pinion bearing of oil.
Always somethin'
I'll fab up my own shims in our shop, no biggie.
Thanks everyone for the replies!
Pat
2 stroke man
34
07-15-2009 12:08 AM
