Resistor pak #19A706
Anyone know for sure if all resistor paks with that part number are the same?
I've been trying to ascertain what the difference is in what the different part IDs mean other than year. EOTH is an '80 model/E1TH is an '81 model. That 19A706 comes with many identifiers, but except maybe for installation method, could that resistor pak have the same values? My F100 has factory AC. I'm wanting to have one/some of these paks on hand....just in case. Thanks
on
That's only a partial number. You need the whole part number. Just because 19A706 is listed for all resistors, does not mean they are all the same, or have the same rating. You need to cross reference the WHOLE number.
Here is a loose example on what Ford part numbers mean, (Following part numbers are for example only):
EOTZ-8146-AA
First section:
E = Decade = 80's
O = Year of decade = 1980
T = Designed for Truck
Z = Parts Department
Second Section:
8146 = Part Identifier = Radiator Shroud
Third Section:
AA = Design Change Code
Just because most all radiator shrouds are numbered with 8146, doesn't mean they are all interchageable with each other. A Truck radiator shroud will not fit on a car for example. But both part numbers will have the part identifier as 8146.
Also, EOTZ does not mean it only fits that year model truck. It means year the part was first designed or changed. There are EOTZ parts on 90's vehicles as example. Also just because it is a EOTZ part does not mean it will fit a 1980 pickup. It might fit a van. That is where the design change code comes in. "AA" in the example above. "AA" may fit a pickup, whereas "E" might fit a van etc....
The same goes with the resistor. You need all of the number. Then you can cross reference that, and see if the numbers have been updated, or if an application can be cross matched.
EOTZ-8146-AA
First section:
E = Decade = 80's
Second Section:
Third Section:
What I'm attempting to find out if there are similar resistors that will work. I'm not ordering any, but if I happen to run across a 19A706 but with a different identifier I'd know it would/wouldn't work.....like at a junk yard/abandoned truck/a NOS part/etc.
I"ve not found any resistance values for checking these paks. Anyone know the test procedure?
Thanks, I appreciate the help.
on
The "H" is the Engineering department responcible for designing the part originally.
Why the above number is called an Engineering number.
If it was the actual part number, that "H" would be a "Z".
"Z" = Part Department.
on
BTW: 1980-1986 F-series use the same resistor, for A/C.
I know you have a different year, but here is a diagram with resistor values for a 93 Ranger, and all the 93-94 trucks and vans have the same values.
I really don't think it matter much what resistors you put in there, as long as the switch has a setting for it, and even then you could bypass a setting, say... med-low, or med-high.
Basically, the lower the resistance, the higher the fan speed, and vice verse.
JBKB
20
05-11-2020 09:12 AM
sross76
2015 + Expedition & Navigator
09-22-2015 05:05 PM
