Is there away to check if i have enough fuel to my engine.It seems worst now from last year.If i floor it up a hill it seems to fall flat on power(not gaining any speed).
Just had the same problem. The in-tank fuel filters got varnished up. Follow my latest posts to find the threads.
BTW do you know what your handle means in Polish?
what do you mean in HANDLE...kupaa? If you were talking about my user name then no.What does it mean.PM me if it's stupid name.
If you don't know what kupaa, or kupa means in Polish, than you want to keep it this way.
Good luck on fixing the fuel problem. I got my fixed. Turned out that I bought the truck 3 years ago with the tank filters already partly clogged. Now my boost goes up to 18 psi, when before the max was 16.
You need to hook up a fuel pressure gauge and see what you pressure is when going up hills.
kupa and kupaa is to different words and I'm not polish I'm Hawaiian
where do i tap into? do i have to cut my fuel line?
There are plugs in the fuel bowl for this type of thing. I used the top plug on the driver's side for mine. You might want to do a search for Brandon's (bdrummonds) fuel pressure gauge setup if you don't want to do an electric one in the cab.
No offense, but you don't have to be Polish to polish your English.
Told'ya not to go there
Coming back to the truck issue, when you open the filter bowl right after stopping the engine and notice the bowl not full, that would be indication of fuel restrictions of weak pump.
I think the gauge is more reliable, but I just pulled the tank filter what was easy with my dump bed.
Now my boost goes where it never went before.
