IPR question
Old May 13, 2009 | 05:28 PM
crack's Avatar
crack
IPR question
im swapping HPOPs and I need to swap IPRs but how the hell do i get it off without breaking the sensor? ive got it loose but its hitting the pump, do i just keep turning? i dont wanna break it, they are pricey, and even if i gota new one id run into the same issue putting it on!
Old May 13, 2009 | 05:29 PM
superduty4x4's Avatar
superduty4x4
You've got to break it down- remove the tin nut on the back and pull the solenoid off, then unscrew the remaining part.
Old May 13, 2009 | 06:14 PM
SuperDoodie's Avatar
SuperDoodie
Yep, what Chase said.. It just comes apart then you need 1 1/8th socket or wrench to break it lose.
Old May 13, 2009 | 07:37 PM
crack's Avatar
crack
ahh I see thanks guys, haven't been here ina while forgot how helpful everyone is!
Old May 13, 2009 | 07:38 PM
PaysonPSD's Avatar
PaysonPSD
Once you remove the nut & spacer and slide off the solenoid you will be left with this.
Old May 13, 2009 | 10:50 PM
crack's Avatar
crack
all is well got it swapped over...thanks again
Old May 13, 2009 | 10:57 PM
PaysonPSD's Avatar
PaysonPSD
Glad you have it under control. Hope both the HPOP and IPR swap solved your problem.
Tim Decker
Dec 23, 2013 08:01 PM
GTRider
Dec 21, 2010 07:11 PM
ozzy460
Dec 6, 2010 03:08 PM
mongo75
Sep 14, 2009 09:32 AM
mwk
Jul 7, 2008 08:03 PM
