Should I replace my IPR at 215,000 miles?
Hey everyone- after being home for almost 2 weeks, I finally am getting to installing my new 17* HPOP. I was wondering 2 things- (1) should I just get a new IPR from the dealer as mine has over 215,000 miles on it, or (2) should I just swap out the old one? If I swap it, how the hell do I get it out? I tried putting the HPOP in a vice and using adjustable wrench on the flats where the IPR meets the HPOP case, but either it's stuck or I need more strenght to turn it, kinda scared to break it. HELP!! I need it back together today!
Thanks guys, yeah, I think I'll stick the old one back in and see how she goes. I'm hoping the somewhat rough idle is from a worn out HPOP. If it goes good, I'll get around to sticking a new one in later on. Thanks for the boost of confidence! I still gotta drop my 55 gal tank and do the intank return mods...... hopefully I don't run outta beer!
Update- Truck's running great, but today when I went outside to run to Lowes for project crap, I saw a oil puddle under the truck so I ran it up, and found the HPOP line at the pump for the pass bank leaking so I thought maybe the fitting was loose from the factory, took a wrench to it and it was tight. Took the damn line off, took the fitting off, the o-ring was perfect. SO I out it all together again, ran it up, and this time looked at it with a mirror and my trusty Surefire flashlight. Sure as chit, the damn line is leaking at the QD. I guess too many disconnects with "other" than the tool made for the job (my shaved 1/2" open end wrench) finally did it in?? So hopefully the stealership has one in stock so I can replace it tommorow..... will it ever end???
Oh yeah it was the line, there's a sleeve under the little rubber wiprer grommet that you push down on, and that sleeve was split like a collar, and that's where it was leaking from. Don't even know how that happens. Oh well, I got it fixed with my "military" discount of $145. Just happy to have her running again!
Sledhead3
13
08-08-2016 11:27 AM
Truxx1956
12-20-2008 09:56 PM
