CB Radio Users Inside!
Old May 12, 2009 | 07:11 PM
big poppa's Avatar
big poppa
Chase and Dave, I run a Cobra 29 heated up a bit with talkback,echo with dual firesticks. I got mine mounted under that cubby to the right of the steering wheel. My friend with the Connex gave me this one. Joe, nice Galaxy
Old May 12, 2009 | 07:25 PM
F350-6's Avatar
F350-6
I've got mine between the sun visors.
Here's some reading for those interested. https://www.ford-trucks.com/forums/6...t-and-why.html
Old May 12, 2009 | 07:32 PM
Izzy351's Avatar
Izzy351
Originally Posted by Quick444
I just recently saw a F250 drive by that has his antenna mounted around the edge of the hood using some kind of mount that probably mounted to the side of the engine bay.
But getting down to the more basics of CB radio. What would I be looking for? I don't have any friends with a CB so I wouldn't be planning to talk on road trips but maybe a few times right now. Can I just leave it on scan and listen in on stuff? Anything I should do? Anything I should NEVER do?
Does antenna height matter? What is this tuning reference?
My suggestion would be to get a mag mount (like a K-40 type) and stick it right in the middle of your roof when you want to use it. I put my VHF/UHF antenna there, and, yes, it makes a huge difference in performance. I don't have a real "CB" in my truck, but my Amateur Radio does everything I need (including CB), so I have no need for "just" a CB. I only put my antennas on when I know I'll be using them. My HF antenna is very large, so I don't keep it on all the time. I also put mine in the garage every night, so they come off then anyway.
Old May 12, 2009 | 07:46 PM
spdmpo's Avatar
spdmpo
I agree that out of the box, the $40 Midlands are as good as the high end units. The best antenna is the 108" stainless steel whip, hands down. No tuning required with that. But if you don't want to deal with that high antenna, find one you like and have it properly tuned. If the CB shop you go to doesn't do it, find another one.
The higher priced units have features such as weather, instant channel 9, recall, scan, and some other things. I have never had a use for these things and stick with a good basic radio.
I use a Uniden Pro 510XL. It's a good radio and reasonably priced. In the Jeep I have an old Midland that works great. Antenna tuning is key to reception... Find a shop that uses a short wave meter, or a friend that knows how to use one.
Old May 12, 2009 | 08:07 PM
fordguy_460's Avatar
fordguy_460
i mounted mine on the back side of my console..my truck has captians chairs and a big center console and with the 6spd my options were shot on the front of the console or under the dash so i put mine on the back side of my console... its still pretty accessable and out of the way for the most part.....F350-6....i like your set-up..wish i had thought of that before i mounted mine.
Old May 12, 2009 | 08:09 PM
Quick444's Avatar
Quick444
What would it cost to have a shorter antenna tuned? Would it be as efficient as the 108? If I were to run the 108 around would it be a problem with hitting things?
Old May 12, 2009 | 08:10 PM
Izzy351's Avatar
Izzy351
It's actually a 102" whip, and the meter used to tune antennas is called an SWR meter. "SWR" means "Standing Wave Ratio". Standing waves on the transmission line (coax in this case) is what happens when there is an impedance mismatch between a source & load. The idea is to keep it as low as possible, which is better for the radio's final output transistor(s).
If anyone needs help with that, let me know. It's pretty simple to tune a CB antenna. You check the SWR on ch 1, ch 20, and ch 40. If the SWR is high on 1, but lower on 40, you have to shorten the antenna. If it's high on 40, but lower on 1, you have to lengthen it. That's the simplified version...
Old May 12, 2009 | 09:12 PM
4inchlovin's Avatar
4inchlovin
I did mine on the front side of my console and my shifter does not hit it...
Its close here, but this is in "low" gear
Heres a better shot of my antenna...
Old May 12, 2009 | 09:33 PM
spdmpo's Avatar
spdmpo
What he said. I mistyped 108, but didn't know what SWR stood for. All this time I thought it was short wave.
Anywho, what I do know about tuning a shorter antenna is that it the placement and the vehicle determines all of this. Other than that, I have my CB guy do it!
Old May 12, 2009 | 09:38 PM
Izzy351's Avatar
Izzy351
I need to correct myself -- I got it backwards!! If it's high on 40 but low on 1, you shorten it. If it's high on 1 and low on 40, you lengthen it. Sorry!!! . Too many Coronas tonight I guess......
Old May 12, 2009 | 10:09 PM
bdrummonds's Avatar
bdrummonds
My little Uniden( a 510 ProXL) is mounted where Chris' is, between the visors. I am running a Wilson 1000 Mag mount, and my little radio has been P&T'd. It will talk out to about 17 miles in the open flat lands of south Alabama and Louisiana, but, throw some hills in the way and it'll only go 8. I like my little radio just as much as the Connex that I had down in LA back in 05, its simple, turn it to a channel, and talk.
Old May 12, 2009 | 10:29 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Who you guys talking to besides truckers? I had my CB in my Ranger truck and heard mostly truckers. Got sick of their BS. It's in the shed now. I will say it was handy for wrecks and traffic jam avoidance. That aside, yawn.
Cell phones seem to be making this obsolete. And yes, SWR is antenna matching theory which is math, along with a check with a meter. It is a trade off in wavelengths. Newer stuff can even compensate for that. New technology is higher in the band and requires none of this matching. Yes, I worked military communications for some years. Not sure where SW is nowadays though.
Old May 12, 2009 | 10:39 PM
  #28
Full Throttle's Avatar
Full Throttle
I have my antenna mounted on my hood with a k40 "trunk mount" system. It just clamps to the drivers side of the hood. It has a great twist off system for when I need to remove it. I also have a Cobra 148 but mine is hooked to a 100W amp. I had a shop tune the cb, amp and antenna and the guy tuning it said if I ever wanted to sell the system, to give him a call! That is how well it works for me.
What ever the system you go with; do not skimp on the antenna and have it adjusted correctly. BTW; I have my cb mouned as close as I could to the floor, under the radio.
FT
Old May 12, 2009 | 10:46 PM
  #29
bdrummonds's Avatar
bdrummonds
Chris and I will talk on the CB when we are convoying to the lake or somewhere else on the road, but for the most part I dont even listen to it around town. There is a BIG T/A truck stop about 10 miles from my house and those boys looking for lot lizards are just down right nasty.
Old May 12, 2009 | 10:49 PM
  #30
Tenn01PSD350
That is exactly what I got sick of and threw my radio in the shed.
