timing pointer - 2:00 vs 10:00
Old May 12, 2009 | 05:41 AM
jwh f-100's Avatar
jwh f-100
The 302 currently in my truck has a 10:00 pointer that is held with two timing cover bolts.
The engine I plan to install has the 2:00 pointer that is held on with the small machine screw and one timing cover bolt. I need to use a water pump with a drivers side inlet.
I plan to throw the new water pump on with a peice of hose as a test but if I can't see the pointer well can I just swap the damper and pointer over from the "10:00" engine??
The build code on both engines is '68.
Old May 12, 2009 | 03:40 PM
jwh f-100's Avatar
jwh f-100
One more question..
Both my engines have '68 build date one is Ford (fairlane torino) one is Mercury (build codes).
The Ford has a 3 bolt pulley/ damper. ( has 2:00 pointer)
The Mercury has a 4 bolt pulley/damper. (has 10:00 pointer)
Can I swap the damper and pointer from the "merc" to the "ford"???
I thought all the older 302s had a 3 bolt. What gives????
Help... Please and thanks..
fordno1
Sep 13, 2016 10:27 AM
James888
Jan 11, 2016 05:23 PM
sixraven
Mar 12, 2014 09:14 PM
luv2ski
Oct 24, 2012 11:35 AM
Toytime
Nov 27, 2011 09:26 PM
