Timing Pointer 292
Old Mar 10, 2014 | 08:58 PM
sixraven's Avatar
sixraven
Timing Pointer 292
I have a 292 that has been thru a few hands before I got it. It has the timing pointer bolted on and a notch on the crank pulley. So I know this is not right....I did a search and see 292 'pointers' with degrees on it also. Which is correct? Pointer on engine and degrees on crank pulley or visa versa?
Lynne
Old Mar 10, 2014 | 09:34 PM
chetspencer's Avatar
chetspencer
My 292 has a pointer on the engine and degree's on the balancer. The big question is if the balancer has slipped with old age giving a false reading.
I've been using a vacuum gauge to set my timing along with a timing light.
Old Mar 11, 2014 | 08:22 AM
hiball3985's Avatar
hiball3985
I think somewhere along the years they may have had a pointer marked in degrees but I have never seen one or know what year or model used them. I have both types of balancers, two marked in degrees and two with just a raised dot cast on it..
If NumberDummy sees this post possibly he can enlighten us.
Old Mar 11, 2014 | 10:16 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2 different timing pointers, the 1956/62 F100/700 original was replaced by another in 1963.
C3TZ-6023-B (replaced B5A-6023-C & B7Q-6023-A) .. Timing Pointer / Obsolete
1956/59 F100/700 272 / 1957/64 F100/700 292 // 1957/63 F750/800 302/332 (Lincoln derived Y blocks) // 1955/63 Ford Passenger Car 272/292/312.
6023 in pic:
Old Mar 11, 2014 | 10:40 AM
hiball3985's Avatar
hiball3985
Thank you Bill
Old Mar 11, 2014 | 08:18 PM
sixraven's Avatar
sixraven
Timing pointer
Thanks guys for the help. I'm having trouble reading the numbers on pulley...any pictures or diagram..
L
Old Mar 12, 2014 | 08:24 AM
hiball3985's Avatar
hiball3985
L
I thought you said you only had a notch on the pulley? Where did you see a pointer with the graduations, I can't find a picture of one.
Old Mar 12, 2014 | 09:28 AM
theodore/teddy's Avatar
theodore/teddy
Refyred
world wide web search
Old Mar 12, 2014 | 10:02 AM
hiball3985's Avatar
hiball3985
Thanks, all my searches turned up nothing. Now I need to find one.
Old Mar 12, 2014 | 02:35 PM
theodore/teddy
Refyred
Jim; Rearcounter and greensales both say they have the B7Q-6023-A! I don't know if that is the single point or graduated pointer, but you could give them a call. I just did a search for the different #'s Bill listed.
Good luck in your quest!
Old Mar 12, 2014 | 02:44 PM
hiball3985's Avatar
hiball3985
Thank you, I had tried that but entering that number at greensales it came up empty. There is one on Ebay for $39 + shipping which I wouldn't pay, I don't need it that badly. I'll keep my eye out at the junk yards and swap meets.
Old Mar 12, 2014 | 07:07 PM
sixraven's Avatar
sixraven
Timing pointer
When I got the engine it had a arrow pointer and the vibration damper was a 2 pulley with a notch. So I figured one or the other was wrong since neither had degree marks
Its in a 1960 F100 and the manual shows it with the single pulley and degree marks on pulley. *So that's how I'm putting it together. If it runs then I guessed right.
*Does anybody have a 292 that has a arrow pointer and degrees on pulley?
L
Old Mar 12, 2014 | 09:14 PM
hiball3985's Avatar
hiball3985
Almost every 292 I have seen has the simple pointer with the degrees on the pulley. I ended up with a couple of extra pulleys with just the single mark, I don't know what year or model it came off of so thats why I want a pointer with marked in degrees.
Boots & Slicks 14
May 2, 2016 11:36 PM
Dylan Davenport
13
May 30, 2012 11:03 PM
phurst
Mar 1, 2011 04:25 PM
therigwelder
Jun 19, 2001 02:34 PM
