icp module ???
Old May 11, 2009 | 07:04 PM
fordsofakingdiesel's Avatar
fordsofakingdiesel
icp module ???
Anyone replace the icp module on a 03 F-350 6.0 diesel? have a false check engin elight.. Put the ol' snap-off computer on it and it says ICP control module fault... any Ideas of where and how to replace it...
Old May 11, 2009 | 07:09 PM
F350-6's Avatar
F350-6
Welcome to FTE. Looks like you missed the 6.0 section by just a hair. We'll get this moved to the 6.0 section for you. The ICP sensor is easy to replace. It just unscrews out of the head, and a new one is screwed back in. Kind of pricey little things though. Make sure you check the wiring connection first to make sure that's not your issue.
Old May 11, 2009 | 07:20 PM
FTE/PARTS-GUY's Avatar
FTE/PARTS-GUY
Former Vendor
I think he is asking about the FICM (Fuel injector control module)? 4C3Z12B599AARM
I've been getting allot of inquires lately about these? hmmmmm
I wish they weren't so expensive, maybe I would be able to sell a few.
Ed
Old May 11, 2009 | 07:25 PM
megawatt00's Avatar
megawatt00
Welcome to FTE! I moved your thread to the 6.0 section. Great group of guys here that will take good care of you.
Old May 11, 2009 | 08:17 PM
DSMMH's Avatar
DSMMH
Replacing the ICP will depend if you have an early or late build '03. The late build ICP is located in the front of the passenger side valve cover. I hope you have this one. If you have the early build like me then the ICP is located behind the turbo on the HPOP access cover. Two options are available to change it. Come in from the top and I believe you have to remove the degas bottle and possibly pull the turbo or come in from under the truck and behind the motor as I did. I had a lift available so I could come from under the truck. If you come in from down under the hardest part of the job is removing the 3 bolts from the turbo heat shield. You have to come in from the driver side and reach over the tranny bell housing. It took me 5 minutes to change the ICP and about 1.5 hours to remove and install the heat shield. I also bought the special ICP Snap-On socket. The only difference between it and a regular socket is the SO socket has a retaining wire around the socket. The ICP sensor is about $150.
DSMMH
Old May 11, 2009 | 08:40 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Funny screen name...
Old May 11, 2009 | 10:25 PM
brickie's Avatar
brickie
What is the code number?
Old May 11, 2009 | 10:27 PM
heavyiron's Avatar
heavyiron
Funny as in Ha Ha, or funny as in you haven't figured it out ...........
Old May 12, 2009 | 11:32 AM
fordsofakingdiesel
the build date is 04/03 so I am assuming its early build... I can't remember off hand the code... It is a neighbors truck I usually work on heavy equipment... He asked me to take a look at it (with this economy everyone is trying to save money) I will get the code tonight.... I personally own a Cummins diesel so don't hold it against me... My company owns all fords 6.0's,7.3's,and gas v-8's and v-10's... Never had major problems with my company trucks so I thought I would try and tackles this one... Thanx for the help. I will try and getin here more....
Old May 12, 2009 | 07:08 PM
fordsofakingdiesel
well I got the codes P2285 and a P2263... Any help would be greatly appreciated guys....
Old May 12, 2009 | 08:56 PM
ljutic ss's Avatar
ljutic ss
P2263 is turbocharger system performance. P2285 is injector control pressure circuit low, ICP sensor.
Old May 13, 2009 | 11:02 AM
david0505's Avatar
david0505
ICP senspr
Hi,Just replaced My early '03 ICP,located under turbo near back of engine..under heat deflector,accessible easier from under truck. 3C3Z 9F838 EA was the no. for mine, I found oil leaking into connector at ICP, ..Guess this is the quick check to prove sensor is bad..after replacing sensor,don't forget to clean connector which goes onto module..might want to check E-Bay motors,enter ICP and search..good luck...Dave
Old May 13, 2009 | 10:29 PM
fordsofakingdiesel
Thanx guys 4 the replies... come to find out the truck in question was in an accident and it was pretty bad.... The original owner never disclosed it was... Truck is going back, This website is better ( than a gasp Cummins ) 4 replies... Thznx again...
Amicus
Dec 10, 2016 01:17 PM
aaronlaaron
Nov 21, 2016 02:46 PM
rdanwhitehurst
Sep 22, 2015 10:11 AM
Cell's
May 28, 2014 04:30 PM
cutlass
28
Jan 4, 2014 11:07 AM
