powerstroke cutting out
Old May 9, 2009 | 05:13 PM
884x4broncoII's Avatar
884x4broncoII
my powerstroke did this a couple times on me a few monthes ago and then the problem went away now its back again and worse. ill be driving down the road truck running great then all of a sudden the truck will start cutting out, somtimes the tach will drop to 0 with the truck still in gear rolling down the road (5speed) other times the tach seems to remain steady. if im traving at an low seed about the only thing i can do to keep from it dieing compleetly out in the middle of the road is to floor it till it clears out, when i do this it billows out white/bluish smoke. i am thinking cps but the fact that sotimes the tach remains steady kinda throws me for an loop.
Old May 9, 2009 | 07:23 PM
Brown Falcon's Avatar
Brown Falcon
sounds like the CPS to me... but could be something else
Old May 9, 2009 | 10:02 PM
sbxworship's Avatar
sbxworship
scan for codes yet?
Old May 10, 2009 | 01:13 AM
884x4broncoII
i have not scanned it yet, i had to leave town right after it started acting up again, took an company vehical, but i am heading back tomorrow, should be able to scan it monday
Old May 11, 2009 | 10:48 PM
884x4broncoII
i got codes P0472 and P0344
Old May 11, 2009 | 11:03 PM
sbxworship's Avatar
sbxworship
I believe p0472 is exhaust back pressure sensor (circuit low), and p0344 is cps intermittent error. To start with, I'd recommend looking into a new CPS; time to cash in on the Ford recall...
Old May 11, 2009 | 11:05 PM
884x4broncoII
is my 96 under the recall, i heard it was only 97's and up
Old May 11, 2009 | 11:11 PM
sbxworship's Avatar
sbxworship
I haven't heard that, but that means nothing. I got a letter about both of my 97's, though. I would think that it would be covered... Either way, it sounds like the problem... If you're not covered by the recall, I think they're pretty reasonable for the updated part (like roughly $40 or something - somebody please correct me if I'm wrong)
Old May 12, 2009 | 06:35 AM
Brown Falcon
the dealership didn't cover my '95 at all for the CPS... said it was a '97 only recall
Old May 12, 2009 | 07:51 PM
sbxworship's Avatar
sbxworship
interesting... are they different or did ford just cheap out?
Old May 12, 2009 | 08:22 PM
don77's Avatar
don77
im thinking they cheaped out myself
Old May 12, 2009 | 08:40 PM
yoslick's Avatar
yoslick
I got mine at NAPA for around $26
Old May 13, 2009 | 09:32 AM
superduty4x4's Avatar
superduty4x4
The 94.5-96 uses a slightly different CPS than the 97-03. I think the only real difference is different metal used on the contacts. 94.5-96 CPS's are also still black, FWIW.
Old May 14, 2009 | 09:45 PM
oldbird1965's Avatar
oldbird1965
I checked the recall on my 96, its not covered.
DieselRugger
Dec 15, 2022 01:33 AM
reelnut
Nov 4, 2016 10:14 AM
fordtrucksforever
Jun 24, 2016 05:08 AM
Rusty_S
Sep 8, 2015 01:08 PM
jlmotox
Aug 14, 2009 06:24 PM
