what causes the FICM to go out?
Got a CEL and took the truck to the dealer and this is what the paperwork shows me...didn't get a chance to talk to the service writer or the tech...
Cause: 58988 FICM failed checked out vehicle and ran tests found P0611...checked PIDS and found FICM PID going down from 48 volts to 28 volts...checked and replaced failed FICM and programed and road tested ok at this time.
truck seemed to run ok with the CEL on the only strange thing I noticed was a couple of times when starting cold it would sputter for a second then run fine...
I see alot of people on here having to replace the FICM...What causes this to happen? is this the "normal" reason for these to go out?
not sure if this is related to the FICM or not but twice now when towing up a long grade the tach will be about 1,000 rpms lower than what it should be and when the engine goes to idle the tach shows 0 rpm but then once I shut the truck down and restart the tach goes back to working normal...there also seems to be a little loss of power when this happens...would that have anything to do with the FICM?
also the new FICM looks bigger...did they update to a new style or type?
thanks!!
thanks!!
i'd like to know too. but in some other similar threads i've read posts stating that the inductive heating flash maybe the problem and also the FICM are sensitive to heat. i'm just passing on what i read, i don't know forsure, all i know is mine went out last year and it cost me a lot of money. i wish there was FICM tuning back then and i could have ordered a new on from Innovative with there custom FICM burning.
not sure what flash I have now but I had the buzz flash but they did a new flash when I had my head gaskets replaced the service writer said it was the "newest one"...
luckly this was done under warrenty! I have heard how expensive they are! ouch!!
is there a benefit to a custom tuned FICM? what does that do for you?
FYI---any FICM from 03-07 will work on any truck. As I understand it there is a common problem with them cracking the solder joints. If you open the FICM up they are very easy to spot. Next to the high current connecting posts, there are 4 wirewound, current limiting resistors laying right next to each other. They are brown and are bigger than any of the other resistors. These develop solder fractures and result in decreased voltage output. In many cases, resoldering these will bring the FICM back to life.
Well, all I can say my truck is still at the shop. Have a new FICM but the shop is having problems getting the programming to load. Ford said they are having issues as well which is causing a delay for my repair. I still do not know if I will be able to get a hold of the 'dead' FICM either. If I do I will be sending it along as promised.
$1150????????? They charged you 600 to put in a $525 FICM??? Did they gold plate it and give you a kiss???
I was told by my tech when mine wen out (under warrany luckily) that they had to send the old one in for testing to see why it failed. Anything under warranty has to sit on a shelf for a certain period of time, just in case the company decides to dispute the warranty claim, the dealer has it to prove their claim to get their money. Also, if this is the case that they are just blowing soldering out, I don't think FORD would be too happy to stop selling $525 FICM's all the time. CASH COW FOR THEM.
Well this is annoying. Day 4 and still no truck. Repair shop the truck is at can't seem to get the programming to load to the new FICM. Ford only communicates with them vie email and Ford has acknowledged issues with the 1-ton programming. At this point I wonder if I will ever get my truck back, or for that matter that the FICM was the issue to begin with.
