Worst day ever...............
Old May 9, 2009 | 01:52 PM
  #31
Supercab's Avatar
Supercab
Wink
Boy, That fellow in the video sure talks alot about his problem!!
Old May 9, 2009 | 04:36 PM
  #32
F350-6's Avatar
F350-6
Originally Posted by Franko72
I just lost some hope, I found this video, and it is EXACTLY what my truck sounds like. Smoke, stalling in gear and all....
YouTube - Bad diesel problems
We know what his problem was. How bad is your blowby?
Old May 9, 2009 | 05:30 PM
  #33
Franko72's Avatar
Franko72
Molon Labe
Im not sure Chris, Its still sitting at the shop 200 miles away. Im going to trailer it home tues or wednesday. I told them to stop working (experimenting) with it. Im not paying $90 hour for someone to guess whats wrong.
I trust the guys here more. between all of us, Im sure there is'nt much we havent seen.
Old May 9, 2009 | 05:37 PM
  #34
F350-6's Avatar
F350-6
Then there's no reason to get worked up about it yet. Let us know when you get it home and we'll all put our heads together and see what we can come up with.
Old May 9, 2009 | 06:00 PM
  #35
schlepprock250's Avatar
schlepprock250
Dude...I would say the cheapest way to get your truck home is to rent a u-haul and a dolly and get er home.
Old May 9, 2009 | 07:38 PM
  #36
Franko72's Avatar
Franko72
Molon Labe
That was plan "B" dolly it home behind my buddy's gas Dodge.....how embarrassing.
Plan "A" flatbed it home behind a F350 dually.
I chose "A"
Old May 9, 2009 | 10:30 PM
  #37
Quick444's Avatar
Quick444
Originally Posted by Bossman7121
Definitely get the truck home and let these guys walk you through it. They've landed jumbo jets online before .. lol
So true!
Keep us updated and go through the recommendations, it will get solved!
Old May 10, 2009 | 06:24 PM
  #38
61 uni's Avatar
61 uni
Got her home yet?
Old May 10, 2009 | 11:26 PM
  #39
Franko72's Avatar
Franko72
Molon Labe
Originally Posted by 61 uni
Got her home yet?
Im leaving in the morning (mon) to go get her. I borrowed my neighbors 01 F350 PS dually and his Bobcat trailer. Lord willing, she will be home Mon evening.
Old May 10, 2009 | 11:53 PM
  #40
Tenn01PSD350's Avatar
Tenn01PSD350
Good luck. Someone will be here. Get it home.
Old May 12, 2009 | 04:20 PM
  #41
Franko72's Avatar
Franko72
Molon Labe
I got her home!!!!!
Its not running all that bad...considering how bad it was running. Still has a bad miss, and shakes, but its not smoking any more. I think the smoke was just the residual from the #1 injector swap.
I was able to drive it up on the trailer on its own power. I had to get a running start, but I did it.
The valve covers are coming off thurs. I think I should start there first? Check all the wires for grounding, the wiring harness under the VC.
Ill start unplugging injectors from there, and double check they are all oiling properly.
Im going to pick up a multi-meter also, to check the ohms.
If I missed anything, please chime in. Im going to try and get this bug worked out one step at a time.
Thanks....
Old May 12, 2009 | 04:50 PM
  #42
superduty4x4's Avatar
superduty4x4
Going out on a limb here, but is there any chance all this is just due to the air in the fuel and oil system from pulling the injector? The smoke being caused by residual oil in the cylinder. Its a SWAG I know but...
Old May 12, 2009 | 05:05 PM
  #43
Franko72's Avatar
Franko72
Molon Labe
Honestly Im not totally sure, It was my first injector swap. The three mechanics at the shop said it should have cleared up right away, but it didnt? Do you think I should let her run for a while? I dont want to do any more damage. Plus I think I had more than one injector go out. It would barely idle when It first lost power.
With the new injector, it idled smoother, but still has no power, and a miss.????
Old May 12, 2009 | 05:10 PM
  #44
superduty4x4
Frank, I've never done injector swaps myself so I can't say if running it a bit will help or not. I just know that when we get air in the fuel or oil system that these trucks run horribly until that air gets worked out. When you said it was running better when you loaded it on the trailer I just got to wondering.
Old May 12, 2009 | 07:07 PM
  #45
F350-6's Avatar
F350-6
After changing an injector, you'll see a decent amount of smoke when you start the truck for the first time. Then it will idle and run A LITTLE rough for about 30-50 miles or so until the air is purged out of the rails.
Pull the valve covers, have a multi meter handy (a torque wrench would also be a good idea) and let us know what you find.
