Transmission Identification Help Needed
Old May 7, 2009 | 08:01 PM
gilllawn's Avatar
gilllawn
I have a truck with the 400M motor in it. I had to remove the tranny because the front seal was leaking pretty good. Anyway it's got a square pan with 11 bolts and the dip stick screws into the side of the pan. It has the following numbers on it:
C8ZP - 7D027-A
10A
17
D50P7006AA
I was told it's an FMX but I want to be sure. I was told it could be a C4. The only thing I can figure from the numbers is it's a 1975.
Thanks
Old May 7, 2009 | 11:37 PM
bigunred's Avatar
bigunred
IF memory serves me right,
FMX 13 bolt Rectangle pan with notch in corner
C4 11 bolts and square
C6 17 bolts and if you are under the truck it has a tip to the back of the pan
hope this helps ya
Old May 8, 2009 | 12:22 AM
85e150's Avatar
85e150
C4 11 bolts, almost square, so it says here:
https://www.ford-trucks.com/article/...ers_Guide.html
Separate bell, aluminum case.
MX trans would be aluminum bell, iron case IIRC.
Old May 8, 2009 | 06:17 PM
mustang81's Avatar
mustang81
14 bolts on mine, i think, and a separate bell. could it be a fmx ?
Old May 8, 2009 | 06:36 PM
gilllawn's Avatar
gilllawn
IT's a C4. Thanks for the help guys.
hairyboxnoogle
Apr 1, 2017 12:11 PM
Tugly
Aug 15, 2016 11:09 AM
wannaBelkhuntin
Jul 20, 2016 09:10 PM
hasteranger
26
Sep 15, 2012 07:03 AM
Tat2ed64f100
Nov 10, 2008 04:27 PM
