E-350 oil pan
Old Jul 14, 2016 | 04:48 PM
wannaBelkhuntin's Avatar
wannaBelkhuntin
E-350 oil pan
OK guys I have a 2001 E-350 with the 7.3 diesel [ambulance] that is leaking oil from the pan. I took it to a local diesel shop and they told me 2000.00 to pull the engine and replace the pan. I have since talked to another mechanic and he thought there is a 2 piece oil pan available that may be installed with the engine in the chassis. Any thoughts on the pan replacement ? 34000 miles on it.
Thanks Dave
Old Jul 14, 2016 | 06:29 PM
vettex2's Avatar
vettex2
Where is it leaking? is it a gasket issue or a hole?
Old Jul 14, 2016 | 07:40 PM
blageurt's Avatar
blageurt
2 Grand is a bit steep .....I would find someone else....I did see a Video on YouTube with a guy using epoxy and a fibreglass Cap over the Pan without removing anything....The Pan itself costs about 200 bucks and the Wacker sealant is about $ 50 ...A grand sounds more reasonable .....The real way is to remove the engine , turn the engine upside down and Install the new Pan with the Special Wacker sealant, wait 24 hrs and put the engine back in ....Good Luck
Old Jul 15, 2016 | 05:23 AM
Wildman25's Avatar
Wildman25
Common problem with that era 7.3, oil pan rotting out.
For what is worth, my old neighbor had to have the oil pan replaced in his '99 F250, 4wd, 7.3, the shop that did it, cut the cross member out, to have access to the pan, and replaced it that way, then welded the cross member back in place, and that was about 5 years ago, and no problems with it, his cost was around $700 out the door.
Old Jul 15, 2016 | 06:35 AM
wannaBelkhuntin
Yes I have seen the fiberglass pan piece, my concern there is I don't think I could get the old paint/rust/oil off of the pan while still in the truck. If I could pull the engine to clean it I would just replace the pan as a pan is cheaper than the fiberglass piece.
If I could find someone that would cut the crossmember I would do that, it has to be easier than pulling the engine.
And yes the pan is rotted out.
Anyone seen or heard of a 2 piece oil pan ?
Thanks Dave
Old Jul 15, 2016 | 07:34 PM
Wildman25's Avatar
Wildman25
wannaBelkhuntin - I just notice that your in the "WesternNewYork" area, the shop that did my old neighbor's truck was in Batavia, if you need, I'll find out the shop name and location.
Old Jul 17, 2016 | 06:09 PM
wannaBelkhuntin
That would be great
Thanks
Old Jul 17, 2016 | 10:48 PM
blageurt's Avatar
blageurt
I have never heard of the imfamous 2 piece pan...But if it was me I would change the Injectors / Glow Plugs / UVC harnesess / rebuild Oil cooler / etc.. etc. while you have the engine out ....So you only do it once.....
Old Jul 20, 2016 | 09:10 PM
Wildman25's Avatar
Wildman25
PM sent with the info.
Tugly
Aug 15, 2016 11:09 AM
Raymond
18
Dec 8, 2011 07:59 PM
jadockins
Apr 5, 2011 10:05 PM
TheBlueMule
Sep 25, 2008 10:16 PM
NY Signman
15
Nov 9, 2004 05:54 PM
