Upgraded Y pipe, etc.
Old May 7, 2009 | 06:40 PM
kalsc's Avatar
kalsc
Curious if anyone has heard of, is using or has feedback on this:
CFM+ 7.3 Powerstroke Intake Manifold
Old May 7, 2009 | 06:48 PM
PaysonPSD's Avatar
PaysonPSD
I have seen this before. Rather pricey.
I read about someone making a split spider out of two stock spiders but don't even remember on what forum.
Old May 7, 2009 | 07:53 PM
Excursion4X4's Avatar
Excursion4X4
I have read about it, but went the the www and saw the price.......
Old May 7, 2009 | 08:13 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I think CSIPSD does that - that's his ID on this forum. Could be wrong, but I'm pretty sure from the discussion of the CFM+ intake for the 7.3
Old May 7, 2009 | 08:43 PM
PaysonPSD's Avatar
PaysonPSD
So it was Joe. Maybe he will chime in.
Old May 7, 2009 | 11:43 PM
CSIPSD's Avatar
CSIPSD
Chime...
If you want to blow $400 on that CFM part and gain nothing then by all means do it! But your going to gain nothing... Its pretty, but unless your collecting purses then... pretty doesnt cut it.
Old May 7, 2009 | 11:48 PM
kalsc's Avatar
kalsc
Fair enough and duly noted.
So if I hear you right, what you're also trying to say is that the heat transfer in the stock unit from the output from the turbo to the cooled post intercooler charge is negligible then?
Old May 7, 2009 | 11:51 PM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by CSIPSD
Chime...Its pretty, but unless your collecting purses then... pretty doesnt cut it.
Hilarious! Effen Hilarious.
Old May 7, 2009 | 11:59 PM
CSIPSD's Avatar
CSIPSD
Yes...
The reason why the intakes make a differance on the 6.0, 5.9 and such is due to air flow, they flow better.
There really is not much room if any to improve the airflow on the 7.3, it has to be the same shape as the stocker more or less. I ported mine a bit to clean it up, cant say it helped, but it didnt cost me anything.
Old May 8, 2009 | 12:08 AM
PaysonPSD's Avatar
PaysonPSD
Do you have a pic of the hot side?
Old May 8, 2009 | 12:20 AM
CSIPSD's Avatar
CSIPSD
Hot side looks just like a H2e hot side... Because it is... You could make a piece very easy with a V band connector like...
Tube Weld Flange - Stainless Steel Tube Weld Flange Vibrant Performance
Then just make yourself a pipe to connect the dots...
Old May 8, 2009 | 08:51 AM
kalsc's Avatar
kalsc
Thanks for the info and feedback. I guess the question that's really on my mind despite the CFM product or making my own, is there any real benefit? Are the charge temperatures that much better or worse pre-sprider and post-spider? I guess the only way to really find out would be to install two Autometer air temp gauges and do some tests.
Old May 8, 2009 | 11:42 AM
PaysonPSD's Avatar
PaysonPSD
Gotcha, thanks.
Old Nov 20, 2009 | 09:48 PM
T8R's Avatar
T8R
Anyone know of a good place to find a stock y pipe? I'm changing out the turbo on my early 99... and the early 99 y wasn't quite big enough.
robjs111
27
May 3, 2016 10:19 AM
stangman516
Mar 28, 2009 05:33 AM
derekmj64
Feb 16, 2009 07:00 PM
