Head gasket interchange
Old Dec 24, 2006 | 01:02 AM
v8xploder's Avatar
v8xploder
Since the 302 and 351 share cylinder heads, What about the head gaskets?? Do the interchange?? I am going to swap my 79 351 heads for 5.0 HO heads and I already have a pair of head gaskets for the 5.0 Id like to use them If I can...
Old Dec 24, 2006 | 11:47 AM
baddad457's Avatar
baddad457
Yea, same gaskets for both. Just make sure you install them correctly. They'll go on either up or down, but they have a front and back. Put them on wrong and you'll have overheating issues. The long triangle shaped port at either end is a coolant passage, the gasket has one end open here, one closed. The closed end goes toward the front. The makes the coolant flow to the rear before going up into the heads. Put them on wrong and the coolant shortcuts up to the heads, you end up with hot coolant in the rear.
Old Dec 24, 2006 | 12:49 PM
v8xploder's Avatar
v8xploder
Thats good that I dont have to buy more gaskets. Thanks for the tips, I got to get my E7TE heads done now so I can get some more HP out of the ol bronc
Merry Christmas!
Old Dec 25, 2006 | 04:25 PM
HemiEater's Avatar
HemiEater
what about the head bolts 7/16 and 1/2.....and the locating pins on the corners are they different.
Old Dec 25, 2006 | 11:23 PM
baddad457's Avatar
baddad457
As far as I know the dowels are the same for small blocks. (221-400M)
Old Dec 26, 2006 | 06:47 AM
desertdave35's Avatar
desertdave35
The 351 uses 1/2" cylinder head bolts.
fire88
1983 - 2012 Ranger & B-Series
Nov 8, 2016 05:42 AM
Valvesmasher198
Feb 5, 2016 01:26 PM
schnide
Oct 28, 2015 09:26 AM
lisagoud
Aug 26, 2005 06:07 PM
bigblocksix
48
Jul 20, 2004 11:59 PM
