max payload
Old May 5, 2009 | 10:35 PM
sljim's Avatar
sljim
max payload
whats the max payload for a f150 4x4 supercab
Old May 5, 2009 | 10:46 PM
pkvir's Avatar
pkvir
It all depends on the model and options. The more it weighs, the less the payload.
For example, my truck with the options listed below has a payload of 1,408 lbs. You can get a Platinum Screw with 4x4 and a 6.5 bed, and it may have a payload of 900 lbs.
Old May 6, 2009 | 06:01 AM
Chris Anchor's Avatar
Chris Anchor
There is another thread that talks about this. Just look at the labels on your driver's side door, one gives you tire specs and the other gives you your truck's payload specs. We found by comparing that it could range from 900 lbs to 3200 lbs depending on how your truck (reg/scab/screw/max payload). It was also pointed out that the lawyers may have downgraded max load for legal reasons. My truck has had more then my sticker states and went down the road fine. Chris
Old May 6, 2009 | 04:43 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I was just going to say "here we go again"! That's a great point about checking the door post becuase only it will have the actual information related to your specific truck. All of the Ford brochures are built around the high figires for a specific chassis configuration but as you add options, your max payload decreases.
Tim
Flyct
2015 - 2020 F150
Jun 5, 2017 01:39 PM
TrailKroozr
2009 - 2014 F150
Mar 2, 2017 08:08 AM
ripstertx
Aug 16, 2016 02:50 PM
Bugzilla46310
Dec 25, 2015 10:13 AM
jason05
2009 - 2014 F150
23
Jun 14, 2008 03:29 PM
