Base Payload vs Max Payload ???
Old Feb 21, 2017 | 06:19 PM
TrailKroozr's Avatar
TrailKroozr
Anyone know the differences between the base payload and the max payload option for the 2014 SCrew? Stiffer springs? Or, something more?
Old Feb 21, 2017 | 08:49 PM
brokenleg's Avatar
brokenleg
max payload has 7 lug wheels and a 8200 GVWR.
Old Feb 21, 2017 | 10:11 PM
TrailKroozr
That's it? One more lug? There must be more to it, isn't there?
BTW: What's is the increase in payload? (2014 EcoBoost, SC, Shorty)
Old Feb 22, 2017 | 01:27 PM
983-over's Avatar
983-over
It also has a 4,800# rear axle, LT tires, different rotors, heavier springs front and rear and heavier shocks front and rear. I don't know if the rear axle is actually heavier or if LT tires up the load capacity.
At one point it had a heavier frame thickness, but I'm not sure if that still applies.
Old Feb 22, 2017 | 04:28 PM
meborder's Avatar
meborder
Same rear axle housing and axle shafts. The 7 lug wheels have a higher weight rating to match the LT tires and increased GVWR. heavier springs and shocks to match.
As to the increase in payload, it depends on the equipment package, but a fair guess on increase would be ~ 8200-7300 for a normal truck and ~8200-7700 compared to a max tow. so between 500-900 pounds additional payload total.
Old Feb 23, 2017 | 12:42 PM
TrailKroozr
I was surprised to see a somewhat small payload of 1141 printed on the driver's door. With a tonneau cover, bed liner, and four mid-sized people, that leaves a mere 300#, or so, for gear. I was hoping that stiffer rear springs was the only difference between the standard and max payload options. That would be a simple upgrade.
Old Feb 24, 2017 | 12:01 PM
983-over's Avatar
983-over
This what you get with the HD payload package.
Old Mar 1, 2017 | 06:43 PM
TrailKroozr
Wow, that's a payload difference of nearly 1,500#. Are you sure the sticker is from a F-150? If so, what cab engine and drive line? My 1141 payload: SCrew EcoBoost 4X4 Shortbed.
Old Mar 2, 2017 | 08:08 AM
983-over's Avatar
983-over
Yep. 2013 F150 XLT Screw RWD eco
JD'sBigredv10
Feb 7, 2019 12:14 PM
crewzer
Jan 14, 2019 01:00 PM
ed from houston
Feb 6, 2008 05:34 AM
calbd
Dec 21, 2003 04:29 PM
workamper53
All Things Towing
20
Dec 11, 2003 01:16 PM
