What intake besides 6637?
Old May 4, 2009 | 06:03 PM
metalshaper's Avatar
metalshaper
Is the AFE the best and quiet or volant or S&B? I am looking for a good air flow and filter that is quiet.
Old May 4, 2009 | 06:21 PM
Pocket's Avatar
Pocket
Everything on the market other than the Ford AIS will be louder than stock. So if you want something that is quiet, the AIS is the only way to go.
The AFE and others are a little quieter than the 6637, since they have some sort of shroud around them that does block a little bit of noise. Still, they are louder than stock.
AIS will flow well until you start adding injectors and a bigger turbo. Then you'll find that it's super easy to instantly suck down the filter minder. So if your power plans are to stay mild, then you'll be fine. The AIS will flow enough air for mild power gains that you get out of a chip or tuner.
Personally, I run an AFE Stage II with the ProGuard7 filter, and it's a great setup. Expensive... but nice. Other kits like the S&B are really good too.
Old May 4, 2009 | 06:24 PM
megawatt00's Avatar
megawatt00
Well put Curtis. The S&B is not to pricey and is relativly quiet. Big Poppa Pump runs one
Old May 4, 2009 | 06:37 PM
metalshaper
Will the AIS handle enough air flow ? I have seen 25LBS boost at WOT pulling the camper on a hill.
Old May 4, 2009 | 06:48 PM
Izzy351's Avatar
Izzy351
It'll handle that. When you get to 30-35+, you'll start running into issues.
Old May 4, 2009 | 07:10 PM
big poppa's Avatar
big poppa
My S-B intake system is a bit louder than stock like Curtis suggested, it gets louder as the the filter gets dirt, that let me know other than looking at it that its time to clean it. There's a few good systems out there and your just at the right place to find what your looking for, good luck.
Old May 4, 2009 | 07:16 PM
metalshaper
Thanks,That might be just what I need.
Old May 4, 2009 | 07:18 PM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
AFE Stage II here.
Love it.
Old May 4, 2009 | 07:24 PM
jdecker88's Avatar
jdecker88
All the ones listed in this thread are great just pick which one you like the best based on design and price.
Old May 4, 2009 | 07:54 PM
Izzy351's Avatar
Izzy351
Just stay with the stock intake. Gene says it's good enough......
Old May 4, 2009 | 08:15 PM
jdecker88's Avatar
jdecker88
Throw a K&N drop in filter in there as well .
Old May 4, 2009 | 08:40 PM
Texas Outlaw
Not a liberal...
And be sure to install one of those "Eugene Ram Air" mods with the giant duct tape and white cone device.
Y'all remember that one?
Old May 4, 2009 | 08:42 PM
Ponyboychris's Avatar
Ponyboychris
AIS here and no issues even pulling a 5th wheel on the passes around my area.
Old May 4, 2009 | 08:47 PM
clux's Avatar
clux
Giving bad advice to new users, even in jest, is bad form.
Old May 4, 2009 | 08:50 PM
Izzy351's Avatar
Izzy351
What? Gene LIKES the stock box! Now you're saying that's bad advice?
