Transmission swap question
Old May 4, 2009 | 04:54 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
I haven't been able to find a lot of info on the transmission that the decoder thinks I have, and I was wondering if any of you know if you can easily swap this one out for another more supported transmission like one of the Borg Warners?
What I have:
1980 F150 Custom 4X2 (8ft bed) with a 302cid, with Clark 4sp w/od manual transmission.
The problem is I think the tranny is going out (keeps kicking it out of second when I am not on the accelerator, and is hard to go into 1st sometimes..), and the parts stores I have checked out don't seem to have anything on this transmission.
Thanks in advance...
Old May 4, 2009 | 06:56 PM
Franklin2's Avatar
Franklin2
I am sure you can swap it out. What I am not sure of is the Clark pattern on the bellhousing, the spline count on the clutch, and the length of the driveshaft.
You can go ahead and get a donor truck that has everything, or you can start with the tranny of your choice, and if something doesn't fit, then go to the junkyard and get the correct pieces to make it work.
Old May 4, 2009 | 08:19 PM
86bigred's Avatar
86bigred
are you sure it's a clark trans.my 81 has a 4 speed od and is factory unit.pull the trans code off the b pillar on the driver side door,and some one here probably can decipher it for you.mine is a bit sloppy as well,but stays in gear.
Old May 15, 2009 | 11:50 PM
6fifty_f1fifty
crapola
decided to change out the oil in the tranny and I think I made a noob mistake. I was pulling what I thought was the drain plug out and just as it was almost out I heard a "tink" and something in me just groaned. I think something fell off of the bolt inside the tranny...
I looked at the b pillar and the code there is "B", the markings on the tranny were a little hard to read but this is what I think they were:
RFD9BR7006-A
C2604194
There is a date stamped 9/12/79 and a "GR BF" right above the date.
Here is a picture of the bolt:
https://www.ford-trucks.com/forums/picture.php
albumid=1661&pictureid=7897
and a picture of the place where I took it out of the tranny:
https://www.ford-trucks.com/forums/p...pictureid=7896
My questions are did I screw it up? and if so, hard to fix? And which tranny it this? It has ford stamped on it as well, either the toploader wanna be or the SROD?
Old May 16, 2009 | 05:47 PM
6fifty_f1fifty
got the tranny out have some pictures, I think maybe i should have started a different thread for this. Oh well you know what they say about hindsight. It's looking like she is a SROD here are this pics:
Tag reads:
RUG DB KK16
E0TRAA2990
Old May 17, 2009 | 08:42 PM
86bigred's Avatar
86bigred
that plug on the side in the last pic is your fill plug.that looks like my trans also.can't help much as i have never worked on one of these.
GrifN
28
Oct 23, 2017 11:06 AM
Fifty4F100
Mar 23, 2014 09:52 PM
6fifty_f1fifty
Dec 4, 2010 09:46 PM
fifty2f1
Sep 19, 2006 01:24 PM
