valve adjustment
Old May 12, 2009 | 10:00 PM
wolfman08's Avatar
wolfman08
I have been trying to adjust the valves in my 84 300. Engine just turned over 100k with no apparent work ever being done other than being converted from propane to gas (sticker on valve cover states that Ford originally set it up to run on propane). Anyway, the rocker arms on #1 cyl. were extremely loose, like 3-4 turns of the nut. I adjusted them per the first method described above and it really quietened the engine down.
A couple of days later I decided to adjust the rest of the valves and noticed that #1 cyl. rocker arms are loose again, not as much, but too loose. Could this be the nuts working loose? Am I just noticing the effects of the lifters bleeding down after the engine has been shut down for a while? Anyone else experienced this?
Old May 13, 2009 | 09:05 AM
Harte3's Avatar
Harte3
You might have to double nut (jam nut) them to keep them from working loose. Lifters might be getting a bit weak but a little clatter on start up is not unusual especially on a cold engine.
Old May 13, 2009 | 09:21 PM
wolfman08's Avatar
wolfman08
Ok can someone explain this. I have gone through and adjusted my valves as follows: I started with #1 @ TDC. Tightened both rocker arm nuts until I felt tension on the push rod and then tightened 1/2 turn more. I repeated the same on 5-3-6-2-4 turning the crank 120 deg. each time. When I get back to #1, the preload on the lifter is nearly gone and I can actually wiggle the rocker arms. Am I not setting the preload correctly? Should I use the 35 ft-lb torque method? The head does not have pedestal style studs. They are just screw-in studs with no step in the shaft.
Old May 14, 2009 | 04:47 AM
dustybumpers's Avatar
dustybumpers
look back in this same post, abandoned bronco said to adjust them by tightining to 35ft/lbs. I did that, and it worked
lm987
Jul 6, 2014 09:19 PM
82f-100
Apr 27, 2009 10:11 PM
reifwj
29
Apr 22, 2008 09:13 AM
sicdefused
Aerostar
Mar 30, 2007 05:00 PM
bh91709
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jan 25, 2006 08:25 AM
