After Market Speed Sensor
Old Sep 25, 2002 | 11:32 AM
FordPerf300's Avatar
FordPerf300
I have a 1993 F150 4.9L M5OD 4x4
I was planning on swapping out my drivetrain for a solid D44, NP435 & 205, and a 9" out back. I know that my truck uses a speedsensor in the 8.8 axle, i was wondering if there were any aftermarket speed sensors, or somthing that could be hooked up to the tranny or t-case (not sure where the old style trucks picked up speed info) Any ideas would be helpful, thanks.
Old Sep 25, 2002 | 11:43 AM
jalampi's Avatar
jalampi
Read though this site and see what Swamp Donkey did to his truck this may work for your truck. He put the sensor at the drive shaft.
http://members.aol.com/_ht_a/jzettel73/Swamp_Donkey.html
1979 F350,4x4,NP435,5:13 gears,Detroit locker in rear with hardened shafts,ABR in the front,L&L Ladder Bars,360 with 428 crank & rods,390 HP heads,Centerforce Dual Friction Clutch,MSD Ignition,39.5x18 Boggers,bucket seats out of a Lightning,& a Southern Body that is perfect.
1997 F350 PowerStroke 4X4,36 Inch Super Swampers, Strait Piped, Chiped, Propane Injected, LUK Clutch
Old Sep 26, 2002 | 07:56 AM
FordPerf300
Wow, he does have some fabrication skills... I would never be able to figure out how to do that speed sensor on my own... I was also thinking, i have the 205 Tcase and it is set up for cable speedo, is there something that could change cable rotations into the electrical impulses needed by latter model fords.
Old Sep 26, 2002 | 03:52 PM
wildjon300ci's Avatar
wildjon300ci
KirkF
Jul 15, 2017 08:57 AM
insightbrewery
Nov 9, 2016 07:17 PM
vintagequest
Jan 20, 2016 05:02 AM
ErrorS
1978 - 1996 Big Bronco
May 13, 2011 08:51 PM
Gary Bacha
Jun 18, 1999 10:53 AM
