Im swapping my 460 to a 6.9 into my 77 F250, but motor mounts are different. 460 mounts are different and where the the motor mounts mount are also diferent, what should i do to mount the 6.9????
My 67 is a 2 wheel drive and You can see some pic's of My mounts in My gallery. I'm doing a 74 right now also a 2 wheel drive I will take better pic's this time
As I do this 74 I will make a print. I didn't write any of it down on the 67 as I normally have to make changes later but I must be getting better at it in My old age. LOL
I've got the engine out of the 79 parts truck and a good start at pulling the 6.9 out of the 86 yesterday.
I'm taking Mom out to diner today for Mother's day (just a reminder for all of You it's next weekend!!!) if I get back in time I'll have the 6.9 out to day.
I'm using the C6 so that end is a bolt in. The truck has factory AC so clearing that is the only concern.
Ok thanks!! well keep me posted on your project, i cant wait to finish my truck, well now im just cutting my firewall to fit the Allison AT545, its a 4 speed auto
This is the part I'll be interested in. I have 3 allison 545s, 2 for Cummins 1 for a Volvo truck.
George D. has one for an IDI.
I cant find motor mounts for my 6.9 diesel!!and i also see in other motor mounts pictures that they have a metal bracket then the rubber motor mounts attach to that, where do i locate those two
I think your talking about the diesel motor mount plate... the idi had a plate that was bolted to the x-member... the motor mounts bolted to that... u can probably find them at a wrecker....doubt it will bolt to your 77 frame but it might with a bit of work... hope that helps
