Motor mounts?????
Old May 9, 2009 | 07:22 PM
562dragnhra's Avatar
562dragnhra
Allison AT545
i have an Allison AT545 4 speed auto but missing some stuff, if you guys have any pics of the tranny with everything hooked up??? where can i find parts?? Allison Transmission doesnt help me
Old May 9, 2009 | 07:45 PM
Dodge/Cummins's Avatar
Dodge/Cummins
I'm going to have to do a lot of research when I get around to using mine too so I won't be much help.
You might want to start a thread just on the 545. If you don't I eventually will.
All three of my 545s are a little different.
I don't know how to post pictures but all three of my trannys are fully assembled but out of the vehicle(s). If you want to know something specific I could look at mine.
Old May 10, 2009 | 12:43 PM
562dragnhra
Where is the neutral safety switch located???
Old May 10, 2009 | 01:23 PM
Dodge/Cummins
The trannys are at my shop, I won't be there until Tuesday but I'll try to remember to take a look.
Old May 10, 2009 | 08:39 PM
1967 Turbo 6.9's Avatar
1967 Turbo 6.9
A little slow but there are motor mount pics in My gallery now.
I've gotten a good start mounting the 6.9 in the older frame
Old May 20, 2009 | 12:57 AM
562dragnhra
THANKS! im having trouble with making motor mounts hoping if you can give me the dimensions? my engine is ready to go in my truck but no custom motor mounts, got the plate and motor mounts alredy bolted to the block and my banks sidewinder turbo, please help
Old May 20, 2009 | 02:25 AM
RLDSL's Avatar
RLDSL
You should be able to get parts for that thing at any medium to heavy truck parts place. An IH dealer should be able to get them no problem
Old Jul 8, 2009 | 12:54 PM
562dragnhra
Do i really have to adjust the injection pump to put the turbo???
Old Jul 8, 2009 | 01:57 PM
RLDSL's Avatar
RLDSL
No, but you won't see the full potential of the turbo if you don't
Old Jul 8, 2009 | 02:05 PM
562dragnhra
if i dont adjust the injection pump and put the turbo would i get more MPG's?? how much should i turn the injection pump allen??
Old Jul 8, 2009 | 09:34 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Most turbo install guides say two flats or 120 degrees.
Old Jul 9, 2009 | 06:16 PM
gonecrazyi's Avatar
gonecrazyi
Did you ever find a set of 6.9 motor mounts? I have a set on a motor that I just pulled from my truck. Just PM me if ya need them.
Old Jul 10, 2009 | 04:49 PM
  #28
71cc's Avatar
71cc
Even if you get the dimensions for every piece, you will still need to fab the mounts in place for it to work. There are compound angles going on. I am building my mounts right now. I started my bolting the transmission and engine together, set in the frame and mount the transmission mount where it would normally be. I assume this is where you are now. Now position the motor centerline the same as the trans yoke within the frame.This will ensure the driveline is straight. The driver's manifold and steering box will limit how low it will sit in the frame. I used foamboard from an arts and crafts store to make templates and taped,bolted and marked pieces to fab up as I went.Double check the engine is level as well as the frame.(right to left) I will try to snap some pics, but I don't know what use it will do you. It is also good advice to shorten the oil pan sump. I started with a new plate and bolted to this
https://www.ford-trucks.com/user_gal...215700&width=0
and fabbed from there.
He has som good pics in his gallery, My motor location looks near identical to this install. Your starter will not be servicable if it is a Mitsibishi, you need a Denso so it can be removed.
Old Jul 10, 2009 | 04:54 PM
  #29
71cc's Avatar
71cc
I just want to make sure you get the credit for the documentation on this swap, it helped me a lot to see your install. BTW the Banks nonwastegated turbo cleared the firewall with less hassle, the turbo and pipe are further in the valley.I am using a 460 super cooler radiator and shroud. It looks like the 7.3 fan will be centered in that, and with the addition of a 6.2 chevy fan blade, the diameter will fit.Thanks for your multiple replies to my PMs regarding this.
Old Jul 18, 2009 | 12:38 PM
  #30
562dragnhra
does any one know how to manually wire the glow plugs?? and also want to wire up the fuel injection pump manually too is that possible???
