exaust questions
Old Aug 8, 2009 | 12:40 AM
wantaford's Avatar
wantaford
Dual looks and sound great. But keep in mind: What are you using the truck for? Cruising, Towing, Racing?
A nice big single exhuast is best for towing, you will have more useable low end torque. Duals are great if you are racing and running in the higher RPM ranges where you need the air flow. Just food for thought!
My old Ford I used to run in high school, was a cruizer, street drag machine. It had a 390 and I had 2.5" duals, with an X-Pipe and Glass Packs. Loud as hell, could never hear the radio. The occasional times I would tow, I had to be in low gears and keep the revs up to climb the steep grades.
Old Aug 8, 2009 | 11:54 AM
ford1puller's Avatar
ford1puller
I was thinking about headers too but then i found out i couldnt pull in the truck pulls because u need stock manifolds. so i just gutted out my first resignator cat and took of my 2nd cat. it loud when u get on it but it can get quiet lol
Old Aug 9, 2009 | 12:07 AM
cchimuk's Avatar
cchimuk
I just put dual cherry bomb turbo's on my ole girl to quite it down some from the shorty headers into nothing but straight pipe that come out just in front of the passenger back wheel, it used to be a screamer but now it has a nice rumble that doesnt get gross when you stand on it at all. i am glad i made the change.
Old Aug 9, 2009 | 09:46 AM
Neptoess's Avatar
Neptoess
dual with an x pipe or single isnt really the question. it's pipe diameter. the thing you're really trying to do is maximize exhaust gas velocity, so a decently sized single pipe(3") or a dual 2" with an x pipe should have about the same effect. Wantas post was accurate as well, smaller/single pipe setups are gonna have higher exhaust velocity in the lower rpm ranges than larger/dual pipe setups, but once the rpms get up there it will switch.
Old Aug 9, 2009 | 11:29 PM
NW 150's Avatar
NW 150
dont go 2 into one, its making all cylinders push exhale into one tube basically, get nice equal length headers, 2.5" to 3" piping and whatever muffler you choose super 44's sound good and belive me, when i say they sound goo they do, i drove a 79 f150 with a 460 that had super 44s and it WAS noticable
Old Aug 11, 2009 | 04:44 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
Yes, this is true, but the fact that all the exhaust is going into one pipe does not make a single system perform worse than duals. A properly sized free flowing single system on a truck will perform as well or better than a dual system. Duals are all show.
Old Aug 11, 2009 | 05:13 AM
lew52's Avatar
lew52
The single system is great for a stock truck but if you have a hi performance truck duels with H or X pipe & long tube headers are great , and the super 44s are nice....Lew
Old Aug 11, 2009 | 06:35 AM
TexasGuy001's Avatar
TexasGuy001
True duals are not necessary on a stock engine. I good free flowing single is good enough. You can get a single in dual out muffler if you want the look of duals. Thats what I did on my truck. If my truck had a built up engine it would probably have true duals.
Old Aug 11, 2009 | 02:04 PM
Neptoess's Avatar
Neptoess
True Duals techinically suck because of the engines firing order. A balanced exhaust system(x pipe) is the best, but 3" single exhaust is milmore than enough for a stock to mild engine.
Old Aug 11, 2009 | 02:25 PM
lew52's Avatar
lew52
Why do duels suck because the firing order???? Splane me .... Lew
Old Aug 11, 2009 | 04:41 PM
94WhiteF250's Avatar
94WhiteF250
I just did some exhaust on my truck, I still have to pass emissions here in NY, so I just cut everything off after the cat, and ran 3 inch cat back, comes out of the cat, splits, and comes out on a 45 after the rear tires, when you are just crusing, its got a decent rumble but it isnt loud and no real cab noise, but as soon as I get on it, shes a screamer... I was happy with it, and only cost me the pipe, no mufflers to just rust away anyway
Old Aug 11, 2009 | 05:18 PM
1966Tbird's Avatar
1966Tbird
you sure you know what your talking about?
Old Aug 11, 2009 | 05:59 PM
  #28
etldak's Avatar
etldak
the federal law say you can not change the exhaust from the converter forward that over rides all states.unless it was built before 1972. i go thew this ni my shop all the time it just depends on looks at it and if they realy care.
Old Aug 11, 2009 | 06:07 PM
  #29
Neptoess's Avatar
Neptoess
I read the true duals thing on a mustang forum. i'd look for the post but it might take a while. basically they said that each pipe will have an uneven amount of backpressure because of the firing order and that and x pipe would help to equalize it and maximize performance. Granted they are probably talking about competitive racing setups, not daily driven trucks
Old Aug 11, 2009 | 06:46 PM
  #30
lew52's Avatar
lew52
In other words you don't know anything about it but what you read, yes a h or x pipe , if put in the right place will help performance, i would like to know why true duals suck because of the firing order,,,When you make a statement like that i want to here what you have to back it up,,, You can teach me somthing,,,, & mustangs are daily drivers just like trucks ... Lew
