defroster vents
Old May 1, 2009 | 07:38 PM
ladelld33's Avatar
ladelld33
defroster vents
i have a problem that i hope that someone can help me with. everytime i turn on the defroster it stays coming out the front vents. the blend door seems loose to me & the vacum works while i'm looking at it. my truck is an 84 f150 with a/c any help will be appreciated greatly!!<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old May 1, 2009 | 07:46 PM
Eddiec1564's Avatar
Eddiec1564
Sounds like the link from the vacuum servo fell off or broke. I had the same on my 84 and its been some time since I fixed it. Check for vacuum to all servos you can get to. I recall with no vac to the controls its usually blows on defrost. The temp blend door is cable controlled not vacuum controlled.
Old May 1, 2009 | 07:47 PM
Hercmech's Avatar
Hercmech
My blend valve broke. I need defrost so I taped blend valve closed. I now only have defrost and floor but I'm ok with it.
Old May 1, 2009 | 09:34 PM
Sycostang67's Avatar
Sycostang67
A popular part to fail on these trucks is the blend door. The hinge breaks and prevents it from going to the default position of defrost. Some have fixed it by installing small brass hinges. I chose to remove the dash ducting, and taped a piece of cardboard over the hole to direct the air. At least now I can choose between the floor and defrost. The A/C never worked and I dont care for the hot air blowing directly at me anyhow.
Old May 1, 2009 | 10:04 PM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Thanks, That just might be whats wrong with mine, rod moves but does nothing to air flow.
I don't like hot air blowing in my face either so I stuffed rags in them!
-Enjoy
fh : )_~
Old May 1, 2009 | 10:48 PM
ladelld33's Avatar
ladelld33
thanks i'll look into this on my next day off. thanks guys for the info!!
Old May 2, 2009 | 12:21 PM
Eddiec1564's Avatar
Eddiec1564
My 84 F250 only had heat option, I got all ducts and parts for AC, installed but never got the AC system working. I do rember that broken hinge now, but the vac lines were a pain as there was no diagrams for it. Once I get a better cab swapped over, the AC will work! Florida summers are getting hotter and hotter nowdays...
Old Jun 12, 2009 | 09:18 PM
sdstriper's Avatar
sdstriper
If you have a vacuum leak at the vacuum can thingy under the hood on the passenger inner fender or there is another leak in that particular vacuum source, you will only have airflow coming out of the defrost ducts. Think smaller sized beef stew can... these vacuum cans rust out. Pull the vacuum line off that can and plug it once to see what if anything changes.
Old Jun 12, 2009 | 10:48 PM
sdstriper's Avatar
sdstriper
Eddiec1564 your cable op statement doesn't apply to A/C equiped trucks. ladelld33, I have the exact same issue and found the tin can (VRESER) is definately the problem, has a hole in it. Found this searching...
https://www.ford-trucks.com/forums/6...ce-can-go.html
Old Jun 12, 2009 | 11:05 PM
Eddiec1564's Avatar
Eddiec1564
Ok, that cable controls the heat blend door. The rest is vac controlled. Its been 10 or more years since I replaced my heat only dash ducts/control over to AC/heat ducts and controls. I do know on my 89 F250 truck it has the same system as the 84. But the 87 truck I stripped had only vac control going to the recir door only. The rest was cable operated. I had to replace the 89 dash as the prevous owner was a hack up repair guy, the 87 dash/ducts and AC control,main wire harness was installed to fix his mess.
I still have not found any diagrams for the vacuum system for the AC controls. Anybody have a factory manual to scan in for all of us here?
Old Jun 15, 2009 | 08:56 PM
ladelld33's Avatar
ladelld33
fellas everything is connected so do you all think that if i service the ac the stuff will work? well i'll see this week cause my youngest can't ride with the windows down that's what the doc said anyway...allergies!
Whensel
Apr 18, 2012 04:21 PM
ABF PSD
Feb 9, 2012 09:26 PM
Matthew.sterbenz
13
Mar 18, 2011 06:51 AM
CrazyHorseUK
May 26, 2010 08:09 AM
CrazyHorseUK
May 26, 2010 03:12 AM
