Petronix gap reccomendation.
Old May 1, 2009 | 07:20 PM
flipklos's Avatar
flipklos
I am finaly getting a petronix flamethrower coil and was currious to see hat a reccomended setup would be regarding plug gap.
1964 F100 292 4spd
Stock cam, dizzy, and C0AE heads. Stock comp ratio. Holley 390 on a 1957-B intake.
I have installed a petronix 1 brakerless ignition. Am now running .036 gap.
Will install flamethrower 1 coil.
Does .040 sound about right.
Old May 1, 2009 | 07:32 PM
YEEHAABILL's Avatar
YEEHAABILL
Sir: Go to the Y-blocksforever site and ask. You will get the answer
and you will be "hooked". Great site & great bunch of guys.....
Bill
Old May 1, 2009 | 08:37 PM
46yblock's Avatar
46yblock
Flip, most guys with the flamethrower coil and Pertronix ignition run .040 plug gap.
Old May 1, 2009 | 09:40 PM
flipklos's Avatar
flipklos
Thanks 46Yblock.
The 64 comes out tomorrow and figured I sould heat it up a bit with the new 4bbl and all.
Winter was long, way too long.
Old May 1, 2009 | 09:44 PM
46yblock's Avatar
46yblock
Have fun, and let us know how all your winter work has turned out.
Old May 1, 2009 | 10:08 PM
flipklos's Avatar
flipklos
I'll let yall know sunday.
Old May 2, 2009 | 02:01 AM
46yblock's Avatar
46yblock
Bill
Yes they are a great bunch of guys, and so here too. Almost everyone here knows the site well, and posts here as there. Perhaps one difference is that this small FTE gathering does dwell on the engine. I notice on the y'sforever site, first tech. page, there are subjects...Bumper rust, oil residure on tire, brake mc, gas tanks, cooling fan, 9 in rear, and mechanical tach repair. No problem but it does get cluttered.
Also, there appears to be an overload on the high performance end, which many cant afford or use, and doesnt suit the truck group well. While saying that I know Charlie and others have very high performing trucks, but it still doesnt fit the main. So thankyou, but I like FTE AND y'sforever.
It is nice to have you drop by.
Old May 3, 2009 | 08:54 PM
flipklos's Avatar
flipklos
Kinda a rough weekend. Fishtailed my uncles car trailer into the ditch on the interstate. Ruined the fender on the trailer and chewed up my taillamp on my 85 F150 in the process. Threw a 1970 LTD into the ditch. Poped both psg side trailer tires off the rim.
We finished rolling the car off the trailer using a 6' prybar and a handyman jack. punched a hole in the fender using the prybar. Pulled the fender up enough to get the tires on. remounted the tires. Hand loaded the LTD with one flat and finaly got her to the farm.
. Finaly I got to fire up my 64. Wont start.................Accelerator pump arm came off the lever. Fixed it, runs great.
I tuned the carb a bit today. Runs sweet. Though It ran terribly rich on the psg bank for a bit this morning. Cleared up on its own so I may need new wires.
By the way. If anyone is looking for a running 390 or a 9" rearend. I will trade for a replacement fender for the car trailer.
Old May 30, 2009 | 10:39 PM
flipklos's Avatar
flipklos
Finaly got the coil in and hooked up. Bypassed the resistor wire. Wow!
Lot better throttle response and a quicker warm up. Softened the exhaust note considerably too. The ignitor gave it getup and go. The coil and gap gave it smoothness and ease.
Now to buy a spare set of points in case my GM one wire burns up the ignitor. 14.7 V is a lot of juice in a primary.
Old May 30, 2009 | 11:50 PM
charliemccraney's Avatar
charliemccraney
14.7 is about normal and should not harm the unit. But carrying a spare set of points and condenser is a good idea.
Wrecklesswisdom
92
Jan 27, 2021 05:55 PM
bjmayberry2
32
Sep 29, 2016 08:24 AM
bjmayberry2
May 21, 2016 10:22 PM
ihcc104
Apr 16, 2016 08:13 PM
bphirt1
Oct 4, 2015 10:02 AM
