Hello. I have a 66 352 motor with Petronix ignition and coil. I have a MSD 6AL ignition box in the attic. Will this work with my motor? Thanks in advance.
One thing though - make sure the distributor isn't all wallered out (technical term) so long as you're throwing parts at it, basically. What I'm getting at is there is likely no difference in performance between the different ignitions, but a new distributor will smooth out idle and drivability and acceleration very noticeably.
