voltage problems
Old Apr 30, 2009 | 09:09 PM
r0n1n's Avatar
r0n1n
voltage problems
at the beginning of a 2 hr trip the voltage needle started bouncing back and forth, then the battery light came on and the needle went to low. periodically throughout the trip the light would turn off and the needle would go back to the middle and stay there for 10 minutes or so, then repeat the whole process.
a quick check produced no loose or frayed wires. with the truck running, i pulled the negative battery cable and the truck continued to run. and the battery tested at 13.8-9 volts. any ideas?
97 F250, the battery is ~5 months old, and the alternator is a rebuilt 105 amp from checker.
thanks, jason
Old May 1, 2009 | 07:15 PM
Franklin2's Avatar
Franklin2
I would suspect the alternator is intermittent. I would get another. By the way that is not good practice to take the battery cable off with the engine running. You might let the smoke out of something
Old May 2, 2009 | 07:43 AM
plapczynski's Avatar
plapczynski
Smoke is bad and expensive!
You might want to give all the grounds you can find a tightening.
Old May 2, 2009 | 09:23 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Agree with ^.... the ground is as important as the positive....lots of people forget the ground is the other half of the circuit in a DC system.
chris64
May 31, 2011 05:24 AM
GregLuke
Feb 18, 2010 09:01 AM
Barndon
16
Jan 12, 2010 09:14 PM
r0n1n
Electrical Systems/Wiring
Jul 7, 2009 11:40 AM
r0n1n
Jun 27, 2009 08:53 AM
