2001 Turn signals
Old May 2, 2009 | 11:30 AM
Papabeardp's Avatar
Papabeardp
2001 Turn signals
I lost my rear turn signals and brake lights on my 2001 F-150. Bulbs look good and I still have running lights. Front turn signals work fine but blink fast. Any one have any suggestions? I tried the owners manual but it's not much help. Any help would be appreciated
Old May 2, 2009 | 09:19 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Bulbs are duel filament, I believe. Pick up a new one and try it...The fast blink on the front is a give-away that the rear is blown. If you don't want to do that, test it with a multi-meter....or ohmmeter.
Old May 2, 2009 | 10:28 PM
Papabeardp's Avatar
Papabeardp
Thanks Bud. I'll give that a try tomorrow. I didn't know if there were seperqte relays for front and rear.
Old May 2, 2009 | 10:36 PM
Franklin2's Avatar
Franklin2
There are no relays. The rear brake and turn circuits both go through the turnsignal switch. If the rear bulbs turn out ok, I would suspect the multi-function switch(turnsignal switch) may be bad, or possibly a loose connection in the steering column.
Mussifto
Mar 27, 2017 10:49 AM
HVACTOM
Feb 14, 2015 04:33 PM
Alias5478
Jan 14, 2012 03:09 PM
farishb
1997 - 2003 F150
Feb 18, 2008 03:23 PM
Drake13
Electrical Systems/Wiring
Nov 26, 2003 02:19 PM
