keys
Old Apr 30, 2009 | 06:30 AM
Mikey D1016's Avatar
Mikey D1016
keys
Do all the new f 150's have the transponder key or is it just specific models? And has anyone gotten any from E-Bay?
Old Apr 30, 2009 | 08:13 AM
v_tach's Avatar
v_tach
All models of the 09 F150 require a programmed transponder (PATs) key to start. You can buy a key (with a chip), have it cut, then program the truck to accept it. The procedure is in the owner's manual.
I did it with a Fusion key off ebay. Its very quick and easy.
Old Apr 30, 2009 | 08:35 AM
Mikey D1016
Thank you for the answer. Is the Fusion key a different type? I heard that one mentioned on another forum.
This is my first new vehicle and these things are all new to me.
Old Apr 30, 2009 | 08:54 AM
Mikey D1016
I foundit on Ebay and through a little searching n forums. Ihave ordered my truck with remote start, so I am not sure if it will work for me. I have only seen the lock/unlock, trunk and panic buttons on them. Thanks again fro the input.
Old Apr 30, 2009 | 09:27 AM
v_tach's Avatar
v_tach
The Fusion key does not have the remote start function.
Old Apr 30, 2009 | 09:40 AM
Mikey D1016
ok thank you. At least I know that I need the transponder key. after my truck comes in I will probably buy one off ebay(a lot cheaper than getting it through the dealer)
Old Apr 30, 2009 | 10:32 AM
v_tach's Avatar
v_tach
My local Lowes has the regular transponder keys. They even had a little electronic gizmo that confirms your existing key has one embedded. I dont recall the exact cost of their replacement but I believe it was less than $15.
They cut my Fusion key at no charge.
Old Apr 30, 2009 | 10:38 AM
Mikey D1016
sweet thanks. I have a lowes that is close and will check into it
90pioneer
6.7L Power Stroke Diesel
17
Apr 23, 2024 03:10 PM
KenRebF-250
Nov 7, 2016 03:28 PM
Bird-Dog 250
18
Dec 12, 2015 10:32 AM
LtDan48
Jun 20, 2015 04:23 PM
sonic
Apr 27, 2004 10:15 PM
