P0107 Map sensor
Old Apr 29, 2009 | 05:39 PM
Bertelrud's Avatar
Bertelrud
P0107 Map sensor
My '96 F-250 started shifting hard now and then a couple of months ago. At that time it started to stall for no reason. It only happened about 3-5 times a week in the start. I changed trans oil and filter without any difference. Last week the truck sometimes would rev really high to before it shifted from 1. to 2. gear. The same day it quit 5 times at low speed but always started again.
I went to pull codes and go P 0107. Map sensor, right?
Can a bad map lead to strang shifts?
Is it common for the map's to go bad?
The current situation is that the truck runs and shifts ok, the next time I accelerate it can shift hard or not want to shift to 2. until 3k or getting off the pedal. It will quit several times almostevery time I drive it and no and then I can feel a wery short moment of lack of power when accelerating.
Any input will be appreciated! Thanks
OldWoodsDiesel
42
Dec 21, 2013 12:02 PM
dmonell
Oct 11, 2013 06:04 PM
dmonell
Oct 10, 2013 11:42 AM
bigbadpowerstroke
Jun 16, 2010 07:02 PM
jmmoral3
1997 - 2003 F150
Dec 13, 2007 10:02 AM
