York Compressor Torque Specs?
Old Apr 29, 2009 | 04:18 PM
Danger_Dave's Avatar
Danger_Dave
anybody? bueller? lol. i am talking about the 5/16 fine threaded bolt that goes into the center of the pulley and holds it directly onto the crankshaft and is what actually turns the compressor when the clutch engages. the other day this bolt vibrated itself loose and there goes my pulley down the freeway. but i got it back and it still works like a champ and keeps me cool. thing is if i overtorque it then the compressor makes terrible noise and load on the engine. i absolutely hate these yorks and will not ever buy another. its remanufactured and blows ice cold and i did all the flushing, vacuuming, and charging procedures believe me. just need to get the specs for that bolt. seems to me its the most important bolt on that compressor. im also going to use lock tite.
Old Apr 30, 2009 | 10:56 AM
Danger_Dave
okay well i guess what i'm gonna do is similar to a driveshaft center support bearing and also similar to an intermediate band adjustment. i'm going to put lock tite, torque it to 15 ft lbs, then back the bolt out 1/4 turn. or i'll back it out and then only torque it to 10 ft lbs. and post up the results, but i'm assuming nobody has this problem or hardly anybody has ac? i luvs me sum cold ac
Old May 1, 2009 | 12:31 PM
Danger_Dave
well i tested the compressor with the bolt backed off a bit and with it torqued down gorilla tight and it makes no difference on the horrific vibration. only happens at 1500 rpms and comes from somewhere inside the compressor. she has plenty of oil and is properly charged. talked to my buddy that used to have a mustang with a york and he says yeah they are pieces of **** and thats just what they do. this really pisses me off though ya know? but then again it does blow 38 degrees from the vents.....
Old May 1, 2009 | 12:36 PM
BradyCouchman's Avatar
BradyCouchman
the one other place i would look for this info is in the offroad section or on an offfroad forum, many people use these for on board air.
Old May 1, 2009 | 02:48 PM
Alvin in AZ's Avatar
Alvin in AZ
Torque specs are usually nothing more than the torque figured out
by the bolt manufacturers for a specific grade, size and thread.
Can I have your York piece of ****? :)
I like ****. ;)
38F? :/
Sounds like it's over charged to me and the icky sounds it's making
also sounds like it might have gotten a little liquid in it. Both.
Flushing?
Did you go and switch to 134a? :/
Did you adjust your TXV?
Alvin in AZ
ps- I rebuilt my original York, it works great. :)
steveh's Avatar
steveh
Check the high side pressure... are you sure you are getting enough air though the condenser?? When it is vibrating.. take a garden hose and cool off the condenser. It could just be the high pressure due to a lack of air flow.
Old May 1, 2009 | 04:55 PM
Danger_Dave
i'm sure theres more reasons for torque specs than that. i.e. head gaskets, i.e. driveshaft center support bearing yoke, i.e. c6 intermediate band adjustment, i.e. wheel lugnuts
I like ****.
please take it. if i can have a sanden in exchange.
38F? :/
no its not overcharged. read this http://www.4s.com/fourseasons/tech_t...ish/ab326.html tag on the original compressor says charge 2lbs of r12. (32 oz) i put 3 cans in it (36 oz) and i also have new custom goodyear barrier hoses which are MUCH larger than stock, and MUCH longer. was properly vacuumed to 28 hg for one hour and i tested for leaks as well. none. low side reading is 35 psi.
Flushing?
yes flushing. you use refrigeration flushing agent and a special flushing gun that you can pressurize with dry shop air and it rinses your hoses, condensor, and evaporator. expansion valve was installed new and so was the compressor
did u see my signature? no i refuse to switch to 134a. it is nowhere near as efficient as r12 and especially in a system that was designed for r12.
no i did not adjust my thermostatic expansion valve. it is not adjustable. it consists of a temperature sensing bulb that connects to the discharge of the evaporator, as well as a pressure sensor that connects nearby on that discharge part, and then feeds a element ontop of the txv. then in addition a spring inside of the unit and all 3 self adjust and provide metering
Alvin in AZ
how did you rebuild it? the rebuild kits i have found just give you new seals and the screen that goes on the head. what about the little crankshaft and bearings inside of it?
mine is remanufactured from four seasons. (one of the top 3 refrigeration giants). i had this same problem with my original compressor, then the same problem with the replacement, so traded it back in, and now the same problem with THIS replacement. all 3 yorks i have experienced put tremendous strain on the engine and would make a horrific vibration that is embarrasing and a nuisance that you can feel shake the whole truck, including the mirrors. but not all at the same rpms. this one does it at 1500 rpms. all other times its smooth as a babys bottom. at idle, smooth. 3000 rpms roaring down the freeway? SMOOTH. oh and its mounted upright, not sideways. has 12 ounces of r12 mineral oil.
read this http://www.4s.com/fourseasons/compressors.html we all know what happens when you assume. but um i'd assume they put out a decent product... dont get why it runs like caca.
Old May 1, 2009 | 05:02 PM
Danger_Dave
i have searched EVERYWHERE. this is because i am so **** about stuff like this and it irritates the hell out of me. this is a good link that i have bookmarked and i take a look at once in awhile York air compressor
Old May 2, 2009 | 11:24 PM
Danger_Dave
any other ideas?
Old May 2, 2009 | 11:28 PM
BradyCouchman
what about going to an old school AC repair shop and ask them?
you could ask some people that have them to go out and check what tourqu theirs are at?
Old May 4, 2009 | 12:27 AM
Alvin in AZ
The rear bearing is nothing more than the -the- most common ball bearing
in the world, a 6203. The front bearing is a Koyo 256211, that's 25mm ID
62mm OD and 11mm thick. Got it off the shelf at an automotive A/C supply
shop. :)
I never said they were the smoothest running or they weren't clunky! LOL :)
I don't want one of the other smooth;) running types in my pickup because
it wouldn't look like -my- pickup I've had for over 34 years if it had some
other type of compressor in it. That's all. :)
Nobody has to like that idea besides me, BTW.
>i.e. head gaskets,
>i.e. wheel lugnuts
Are you going out of your way to find fault with what I say or does it just
look that way?
>>I like ****.
So, they both have the same value to you? ;)
I took a Sanden apart, it was very impressive inside. :)
>>38F? :/
>no its not overcharged....tag on the original compressor says charge
High side pressure?
Suction line temperature at the compressor?
Heck no. :)
I don't have that sissy crap turned on. LOL :)
I'm a newsgroup junky. :)
Well, what do you know, we actually agree on something else. LOL :)
Wow, that's a new one on me, never even -heard- of a TXV that was
-absolutely- -not- adjustable! LOL :)
>metering
I know how it works. LOL :)
At first it sounded like you might have slugged your compressor but now
I believe it's more just a case of you just bitching about normal old Ford
pickup stuff, and it not being good enough for you. ;)
Which is it, Dave? :)
Alvin in AZ
Old May 4, 2009 | 12:27 PM
Danger_Dave
shop.
damn. how in the heck did you know all that? if this thing blows then i will definitely get new bearings, but i'm thinking if that happens it will be more than just bearings to be concerned about. the metal fragments and sludge that gets created will destroy my whole system. thats my biggest fear because i have torn down this whole thing and spent way too much time and money on this a/c project so i expect it to work PERFECT. Bill busted his *** to find me the last expansion valve NOS in existence, removed the evaporator core and flushed it out. put ALL new hoses on it custom made by amazon hose in orlando fl. new dryer. flushed out the condenser several times. gone through 2 compressors now, i am on my 3rd one. properly vacuumed the whole thing, properly charged it with r12. i would estimate i spent 100 hours on the project total. and about a thousand dollars. so is PERFECTION too much to ask for?
look that way?
no, not going out of my way or trying to be offensive at all, i just HAD to disagree with that statement because i have become a big fan of torque specs since theres no possible way of knowing if a bolt is too tight or not tight enough and the consequences have bit me in the behind! and besides i am a fan of the way your posts are itemized so i had to go ahead and itemize mine as well
yeah from the research i've done a sanden is more valuable to me and a much better compressor
High side pressure?
okay i will take readings and get back to you
well i'm just saying that its self adjusting due to those factors that it senses.
how did you adjust yours?
Which is it, Dave?
its neither. i charged this one with the cans rightside up the whole time and never ever turned them upside down to cause liquid to enter the compressor. i have made that mistake before. and i have no complaints about old ford pickups. i love my truck. i think ford makes the best pickup. harley makes the best cruisers, japanese make the best crotchrockets, and excuse my french, but i like some of chevy and dodges muscle cars, but their trucks are caca! i am ford truck all the way! i am just sick to my stomach over the design of the a/c systems on these things
Alvin in AZ
Old May 5, 2009 | 01:05 AM
Alvin in AZ
$1000(!?)
Holy crap, Batman. :)
I've been messing with A/C for just a few years and at this point I believe
A/C work takes experience to master and a one-up job, attacking it like it
was an engine, buying fancy parts for it, won't make it work any better if
you don't know what you are doing. And sad to say I don't know what
I'm doing in the time I've been messing with A/C and prob'ly never will. :/
Perfection?
Sorry, but yes, that's too much to ask for, IME. :/
Liquid can creep up the suction side and get in the compressor if it's the
least bit over charged. The incoming cool vapor cools the compressor.
It's a case of "a little bit more" is suddenly way too much, if liquid forms.
You'll see those guys feeling the suction line to be sure their new charge is
ok, but it's only a "double check" not to be relied on to charge a system.
Take your old TXV apart and you'll see the adjustment feature.
It's under the screw-on cap on the bottom of the TXV.
A 1/16 turn is quite a change so take it slow and easy (as you know).
I used a mirror (hard drive platter ;) to help me with mine.
I ain't a -real- A/C guy. :/
Real A/C guys don't talk about adjusting the TXV much. ;)
Took a -lot- of reading to find a single reference to it.
Was wondering if that wasn't the problem with mine, see?
Sure enough, ended up turning it like 3/16 of a turn and fixed my pressures
and temperatures and everything.
What got me to thinking about it was how the numbers weren't adding up,
it acted like it was too closed, and it was.
Alvin in AZ
Old May 5, 2009 | 11:16 PM
Danger_Dave
$1000(!?)
Alvin in AZ
oh believe me, i'm the last person to just throw money and throw parts at a problem hoping to fix it. i will go very much out of my way to hit the books and troubleshoot something properly.
but when you buy an as is factory a/c setup off ebay that has tons of pictures and looks like a great buy, then end up finding you you have rust in the lines, cracks and leaks in the hoses, busted crankshaft in the compressor, stuck shut expansion valve, and black death sludge in the condenser then you gotta do what you gotta do.
FuzzFace2
Nov 3, 2019 09:26 AM
1972RedNeck
Apr 8, 2016 10:50 PM
dtgl90vt
Feb 6, 2016 09:07 AM
ManfredVonRichtofen
WTB - Parts & other
Jan 1, 2016 11:45 PM
sjones
Nov 14, 2002 06:36 PM
