Hidden Kill Switch suggestions
Old Apr 28, 2009 | 02:27 PM
Bossman7121's Avatar
Bossman7121
Originally Posted by superduty4x4
How did you wire that up?
You can also wire a switch to the hot lead on the starter solenoid on the fender that will keep the starter from engaging- I think Robin (PaysonPSD) has a write-up for that somewhere.
Hold please while accessing 1983.....
If I remember correctly the first time we used a sliding side contact thing, which was basically a pc of sheet metal bent in half, and pinched between the sides of the ashtray. Soldered 2 wires to each bent half and ran them to a relay switch interrupting the hot to the starter. Pushing in the ashtray pushed the metal together and created a circuit which opened the contactor to allow power to go to the starter. After that wore out and kept shutting the car off when driving we switched to a push button switch. Pushing in the switch when closing the ashtray completed the same circuit. Young and dumb....
Old Apr 28, 2009 | 02:39 PM
superduty4x4's Avatar
superduty4x4
It actually sounds like a pretty good idea to me! Interesting to say the least. I never would have thought to try something like that!
Old Apr 28, 2009 | 02:43 PM
Bossman7121
Keeps it simple, and ALWAYS good for a laugh when you send out one of the guys for coffee in it ! ! They pull out the cup holder and no go !
Give me a week and I'll do it by then, unless someone beats me to it.
Old Apr 28, 2009 | 03:06 PM
superduty4x4
That would be a dirty little trick... I like that idea!
Old Apr 28, 2009 | 03:08 PM
guitarpicr's Avatar
guitarpicr
Also could use a small micro switch - Furnace blower door switch would be a good one for about 6 bucks at any heating & cooling supply house.
Old Apr 28, 2009 | 06:58 PM
Full Throttle's Avatar
Full Throttle
Originally Posted by mybigredford
hmm, i like this idea, what items did you use and how did you do it?
I use this simply as a diversion. Like I said; if it will delay them long enough, they might just leave it alone. And as it was stated; if the truck is running and someone is crawling around trying to find a switch, I'm sure it would draw some attention.
As for what I did: Your break switch has a few wires going to it. One of them controls a pin in your steering column. I just broke the circuit with a toggle switch. You can put that switch anywhere you want. I wired mine to look as if it was wired by the manufacturer so it would not be detected.
Also, do not use a grounded L.E.D. lighted switch. With these switches off, as you hit the break, it charges the switch and turns on the light in the switch. It may give it away what that switch if for if noticed by "The Enemy".
FT
Old Apr 28, 2009 | 09:34 PM
60RatRod's Avatar
60RatRod
Originally Posted by Full Throttle
I had a neighbor who was a tow-truck driver and he said that it would be hard to break the pin that keeps the gear-shift from moving. He had tried many times on vehicles that were totaled.
FT
I agree, I needed to get one at the junkyard for the O.D. switch only. So I took my sawzall with a good metal blade and Holy S$1! could'nt even cut through it. Amazing.
Originally Posted by HH60FE
Fellas, I'm not the computer ****, but be careful what you post here, don't want the enemy to know too much.
Man you're absolutely right, good call.
A picture Write or Thread would be cool, you know pics are always cool. Also differnt ideas are helping just need to decide on what way I want to go.
oldguard60
26
Mar 1, 2021 08:47 PM
rews2
Aug 4, 2014 12:43 PM
rebelyell618
May 4, 2008 07:46 PM
F2504x4
Sep 3, 2004 09:40 PM
HeatStroked
15
Jan 11, 2004 10:18 PM
