MY IC THREAD-spyder pipe found
Old May 20, 2009 | 04:09 PM
2 stroke man's Avatar
2 stroke man
here we go....i got it now...$87 delivered. what else do i need? i'm goin to get the actual IC tonight, and the pipes as well.
Old May 21, 2009 | 10:13 AM
Neal 97 250's Avatar
Neal 97 250
Looks like all you need is some clamps and some time. I used a sawzall some but the best tool I used was a grinder with some cutting wheels. Get quite a few cutting wheels. Be careful of the radiator.
Old May 21, 2009 | 11:18 AM
2 stroke man
Are the intake pipes on the heads any different?
Old May 21, 2009 | 11:34 AM
Neal 97 250
If you have an early '99 Y-pipe and it looks like you do it will just drop in. The boots you have on that Y-pipe will fit your intake manifolds.
On a side note, have you heard back from the guy with the axles? I will need that plate on the bottom of the axle.
Old May 21, 2009 | 01:43 PM
2 stroke man
I will try to rattle his chain today
Old May 21, 2009 | 07:40 PM
FARM69's Avatar
FARM69
The early 99 is a direct bolt in for our trucks. Just make sure you change the clamp that connects it to the turbo. The old one will work, but it won't seal correctly.
Old May 21, 2009 | 09:06 PM
2 stroke man
i don't have the right clamp then. what must i do to get one? the guy who had the Y pipe didnt have one.
Old May 21, 2009 | 09:15 PM
J'S97F-350's Avatar
J'S97F-350
the v- band clamp for the turbo connection is ford #F81Z-6C640-FA....dont forget to plug the sensor with 3/8 pipe flush plug and the hose fitting is tapped to 1/8 pipe also flush plug. this all assuming you still have the fuel bowl...give us a yell if we are not coverin what ya need
Old May 21, 2009 | 09:36 PM
2 stroke man
dang man you are better than the guys at the ford parts counter.....way better
Old May 22, 2009 | 07:34 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Im not sure about this but IIRC the y pipe is 2 3/8" and the stock intakes are 2" so you need a reductor boot maybe somebody correct me
Old May 22, 2009 | 10:35 PM
J'S97F-350's Avatar
J'S97F-350
you are correct . th y-pipe is 2 3/8 and the intake plenum is 2"......but if you look @ his pic, it looks like he has the oem early 99 boots
Old May 25, 2009 | 01:27 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
Well I have in my book that that ford #F18Z-6C640-FA is for the couplers for the Y pipe, and I have this for the <link rel="File-List" href="file:///C:%5CDOCUME%7E1%5CJAGJ%5CLOCALS%7E1%5CTemp%5Cmsoht ml1%5C01%5Cclip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><style> <!-- /* Font Definitions */ @font-face {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:536871559 0 0 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:ES-MX;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]-->Clamp (Y-pipe to 94-97 compressor): F81Z-8287DA or M/craft Service Part #YF-2488
Ok, thank you, you are right. I thought that the early 99 has different size of the intake plennums than the OBS.
Lhornung
115
Mar 19, 2017 08:51 PM
Ezalycasaid
Aug 10, 2015 04:13 PM
Groundpounder0331
Sep 2, 2013 12:11 PM
Dave Sponaugle
13
Jul 26, 2010 08:06 PM
redone1
21
Aug 28, 2009 01:46 PM
