Radius Arm Bushing Replacement
Old Apr 25, 2009 | 11:25 PM
smokeyb97's Avatar
smokeyb97
I know this has probably been gone over before, but I can't get the end of the radius arm to clear the bracket. I've removed the spring and shock from the upper mount and still can't pry the radius arm far enough back to clear the bracket. Is drilling out the rivets on these brackets my last recourse? This is a 79 F100 2wd.
Old Apr 26, 2009 | 02:11 AM
bmarkline's Avatar
bmarkline
...............Turns out when u screw up on a post, you cant go back and erase it haha, read the one below, this ones my screw up.
Old Apr 26, 2009 | 02:13 AM
bmarkline's Avatar
bmarkline
They are talking about radius arm stuff in another thread right now, Follow this link:
https://www.ford-trucks.com/forums/8...radus-arm.html
See if this helps good luck
Old Apr 26, 2009 | 07:36 AM
firstonraceday's Avatar
firstonraceday
It's my understanding from previous threads that in the case of a riveted radius arm bracket, a comealong is used to pull the radius arm far enough forward to clear. I can't speak from experience as my 77 F-250 had bolted brackets.
If you're planning to keep the truck long enough to need to change bushings again in the future, you might be ahead to drill out the rivets and replace with bolts - Grade 8.
Old Apr 26, 2009 | 10:06 AM
smokeyb97's Avatar
smokeyb97
Thanks, I was hoping I could do this without removing the brackets, but that looks like what I'll have to do.
Old Apr 26, 2009 | 12:15 PM
hotrodkid13's Avatar
hotrodkid13
I used a come-a-long to get mine back in there, it was still a pain in th ****, but it worked.
Old Apr 26, 2009 | 07:41 PM
smokeyb97's Avatar
smokeyb97
Where did you hook the come-along, to the frame rail up front?
Old Apr 27, 2009 | 08:29 AM
old76er's Avatar
old76er
I don't know if anybody else ever did it but when I changed mine I hooked a chain to a telephone pole then to the axle then had somebody watch as i backed the truck up enough to clear, set the parking brake then changed it. It went pretty easy
Old Apr 27, 2009 | 10:14 AM
smokeyb97's Avatar
smokeyb97
I can't do that because it's in the driveway with nothing to hook up from.
Plus, it does'nt have the engine or transmission installed yet. Looks like drilling the rivets may be my only solution. Thanks.
Old Apr 27, 2009 | 05:13 PM
hotrodkid13
i hooked it to my bumper bracket
Old Apr 27, 2009 | 05:36 PM
classicfordman's Avatar
classicfordman
you could just remove the suspintion from the front and it should slide right out when you drop the coil spring, shock, and I-beam..the radius arm will pull forward with it.....
Old Apr 27, 2009 | 05:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Go ahead...drop that coil spring...and see what happens.
The coil springs are under TREMENDOUS pressure and can take you head clean off if one is not careful.
I saw a coil spring fly over 100 feet once...when some goofball removed it without using the appropriate safety equipment.
Old Apr 27, 2009 | 06:02 PM
smokeyb97's Avatar
smokeyb97
I've already had the coil spring and shock out from the upper mount. I had the truck supported with jack stands and used a floor jack to lower the shock and spring from their upper position. My problem was a couldn't pry the radius arm far enough back to clear the bracket, it needed about an inch to clear.
Old Apr 27, 2009 | 06:06 PM
smokeyb97's Avatar
smokeyb97
Thanks, I'll try removing the I beam next.
Old Apr 27, 2009 | 09:44 PM
classicfordman
i have removed the intire front i-beam, hub, spring assembly from these trucks, if the wheel is off the ground suported by the FRAME then there is no tension on the coil spring...take out two bolts and two nuts and its all out from under the front of the truck....i had to change one on my 73 f-100 about two and a half years ago with nothing but a floor jack ratchet and a few sockets.
