Radius Arm Bushing Replacement
Old May 4, 2009 | 07:22 PM
  #31
flcracker9's Avatar
flcracker9
Originally Posted by RCrawler
Better re-read my post then. The I-beam and radius arm are not connected to the spring at all when pulling. The only tension you are pulling against is the I-beam bushing.
Probably more of a danger to get rivet grinding dust in your eyes or smacking your hand with a hammer driving them out
Jason
I don't need to re-read your post. My comments weren't based on your post to begin with, but based on a couple of posts regarding using come-a-longs. The OP asked for advice, and I gave it to him. You also gave him your opinion. Leave it at that and move on, let him decide which way he wants to do it?.
Old May 4, 2009 | 09:37 PM
  #32
RCrawler's Avatar
RCrawler
Obviously, the OP can use any method that suits him. That's not the issue.
My issue is that you convey that using a come along is an unsafe way to do the job. Which it is not. Everyone that posted about using this method stated that the coil was not connected to the beam while pulling on it. There is no danger involved in doing it this way and it doesn't take that much force to move the beams forward far enough to service the bushings.
On a side note: if you are going to damage the pivot bushings by pulling forward on them, chances are they need to be replaced anyways.
Jason
Old May 5, 2009 | 12:13 AM
  #33
Alvin in AZ's Avatar
Alvin in AZ
...going to damage the pivot bushings by pulling forward
Jason
I couldn't agree more. :)
But then that isn't that the way things are usually done by
the guys asking how to change the radius arm bushings. ;)
Did you ask anyone how to change radius arm bushings? LOL :)
Or did like I did, climbed under there and hatched a plan? ;)
Alvin in AZ
Old May 5, 2009 | 12:24 AM
  #34
RCrawler's Avatar
RCrawler
Alvin in AZ
I've done them all sorts of ways and watched how other guys did them. Found a method was the quickest and most painless way to do it, IMO.
Jason
Old May 5, 2009 | 06:54 PM
  #35
trailblazer28333's Avatar
trailblazer28333
i've done it the come along way and the grinding the rivets off way.
will never come along it again.... much simpler to remove the rivets and replace with bolts and it also ensures the next time u will only spend about 25 mins changing both sides.
Old May 5, 2009 | 07:39 PM
  #36
flcracker9's Avatar
flcracker9
[quote=RCrawler;7464452] Everyone that posted about using this method stated that the coil was not connected to the beam while pulling on it. [quote]
I know I should let this debate die, but I guess I'm as stubborn as RCrawler. Below are 2 different quotes from this post, that mention nothing about removing the springs or relieving the pressure prior to using a come-a-long.
"I used a come-a-long to get mine back in there, it was still a pain in the ****, but it worked"
"It's my understanding from previous threads that in the case of a riveted radius arm bracket, a comealong is used to pull the radius arm far enough forward to clear."
Old May 5, 2009 | 11:21 PM
  #37
RCrawler's Avatar
RCrawler
It doesn't mention anything about jacking the truck up either...
I wonder how dangerous THAT would be?
I don't consider a one line post to be a tutorial on doing something like this.
A come along is one of the most valuable tools in my tool box and it gets used alot. It can be used to pull something apart, bring stuff together, lift, lower, secure, etc. 100's of uses.
If you are wary of using one this way, don't do it. But no reason to thwart someone else because you think it is unsafe.
The truth is, I've seen more people go the the hospital from a 4 1/2" grinder than I ever have from a come along.
Jason
Old Apr 16, 2011 | 10:21 AM
  #38
74 Work in Progress's Avatar
74 Work in Progress
interestingly I didn't interpret any statement that said that using a come along was UNSAFE. Only that grinding the rivets was SAFER.
Dcameron826
Jan 14, 2017 07:50 PM
stirling35
Jul 4, 2016 09:08 AM
MY FYN 79
Oct 18, 2015 04:13 PM
alchemist1
17
Apr 8, 2013 08:46 PM
FordPerf300
Offroad & 4x4
Jul 10, 2002 06:37 AM
