Radius arm bracket
Old Jan 14, 2017 | 02:43 PM
Dcameron826's Avatar
Dcameron826
Radius arm bracket
I found a 1978 f250 2wd locally that has a broken driver side radius arm bracket. I'm considering buying the truck but haven't found the bracket on any sites I've looked at. Where can I order one of them? I did find an NOS part on eBay but they want $100 for it which seems rather high.
Old Jan 14, 2017 | 02:54 PM
papasmurf40's Avatar
papasmurf40
Try Rock Auto?
Old Jan 14, 2017 | 03:00 PM
Dcameron826
I looked already. All I saw was bushings and nuts. I don't think they have the bracket
Old Jan 14, 2017 | 03:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Dcameron826
I found a 1978 F250 2WD locally that has a broken driver side radius arm bracket.
D8TZ-3B095-D (replaced C5TZ-3B095-C & D3TZ-3B095-B) .. Left (drivers side) Radius Arm Bracket / Obsolete
1965/72 F100/250 2WD / 1973/78 F100/250 Regular Cab 2WD / 1974/78 F250 Super Cab 2WD except w/8,100 lbs. GVWR
RED TAYLOR FORD in Corning AR has 1 = 870-857-3518.
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
NOS PARTS LTD in Waxahachie TX has 1 = 972-937-2201.
MILLER OBSOLETE PARTS in Binghamton NY has 1 = 607-722-5371.
Note: Ford changed the brackets and the radius arms in 1979. Both as a set can be used on 1965/78's, but not individually.
Old Jan 14, 2017 | 05:17 PM
Dcameron826
Any idea if one from a 80s truck will work?
Old Jan 14, 2017 | 07:01 PM
NumberDummy
No it will not, because 1980 and later is different than 1965/78, different than 1979.
The bracket used in 1979 will only work on 1965/78's if you also use the 1979 only radius arm.
Gee whiz, I already gave you the applications for the correct bracket and the sources that have it NOS
Old Jan 14, 2017 | 07:50 PM
Dcameron826
I know and thank-you for the information. I was just curious because I have a stripped 1982 frame and wanted to know if those brackets could be modified to work.
bucktheworld
WTB - Parts & other
Dec 13, 2016 10:03 AM
FordStolz68
Mar 10, 2016 08:42 PM
alchemist1
17
Apr 8, 2013 08:46 PM
PIDI
Apr 29, 2012 03:50 AM
Dajacks1
Oct 20, 2010 04:28 AM
