motor problem
Old Apr 15, 2011 | 05:48 PM
jonnykford's Avatar
jonnykford
motor problem
I have a truck with oil on the drivers side front plug. is it bad or small cheap fix?
Old Apr 15, 2011 | 05:54 PM
jim collins's Avatar
jim collins
I would check for a valve cover gasket that needs to be replaced or at least check to see if the bolts are tight.
Old Apr 15, 2011 | 05:56 PM
jonnykford's Avatar
jonnykford
cover gaskets are good. any other stupid little things to check or is it time to pull the motor?
Old Apr 15, 2011 | 07:04 PM
jim collins
What engine is it ? Kinda hard to visualize what the problem is with out more information. Of course if you are looking for a excuse to pull the engine ,then go for it.
Old Apr 15, 2011 | 07:32 PM
jonnykford's Avatar
jonnykford
im sorry its a 351m
Old Apr 16, 2011 | 07:59 AM
jim collins
How well does it run,missing,ect ? Is that cylinder working or is it a dead cylinder ? If it's not working,check the part of the plug that is in the engine to see if it's oily there. If it's oily ,then you have more problems than a minor oil leak . Good luck, JIM
Old Apr 16, 2011 | 10:43 AM
jonnykford's Avatar
jonnykford
it runs good it just starts alittle hard when hot
Fastolds
Ford Truck Parts for Sale
Nov 25, 2012 02:10 PM
wosborn
13
Mar 29, 2006 02:40 AM
chado
Ontario Chapter
Jan 15, 2003 07:48 AM
Earl
May 31, 2002 09:13 AM
dslman
Aug 5, 2001 11:46 AM
