Sponsored by: Real Truck
overloads
Old Apr 29, 2009 | 11:33 AM
F350-6's Avatar
F350-6
I was thinking of doing the same thing since I had to remove those for my airbag install. That covers one end of the spring, but I'd like to find something for the front side so I get contact there too. Let me know if you come up with any ideas for this.
Old Apr 29, 2009 | 11:45 AM
cartmanea's Avatar
cartmanea
I wouldn't trust that. The spring is putting a lot of side force on that bump stop under load and it will probably tear the rubber off eventually.
Old Apr 29, 2009 | 07:51 PM
surveyguy's Avatar
surveyguy
I'll let you know F350, i do have front and rear covered. one touches the stock pad already with camper on, and the fourth i put a steel tube between the stock pad and the mount. I cut with my torch, a slot that would allow me to pop it in with a hammer (like the stock mount).
Old Apr 29, 2009 | 08:20 PM
F350-6's Avatar
F350-6
That's what I was thinking too. I'd go with 2 bolts in the tubing to keep it from rotating. You'll notice the bump stop you put in the rear had a nipple next to the stud that keeps it from rotating.
How hard was it to get the factory rubber out of the support? Did you pry it down from the top, or punch it out using a hammer?
Old Apr 29, 2009 | 08:25 PM
surveyguy's Avatar
surveyguy
I don't see that one spinning,it fits flush with the back. i also don't see them breaking, i'm thinking of the force of the full truck they designed it for, and the springs are giving. it'd have to bottom out to get huge forces, and that's against the regular springs and the timbrens. The camper & bed would have to be so far tipped if the went all the way down (don't see it with the timbrens) If they do fail, i'll make mention of it. thanks for the "second set of eyes" dudes!
i used two large screwdrivers and then just pry down, came out stiff but not bad.
Old Apr 29, 2009 | 08:53 PM
F350-6's Avatar
F350-6
If it doesn't rain, I know what I'm doing this weekend.
Thanks.
Old Apr 29, 2009 | 09:11 PM
cartmanea's Avatar
cartmanea
When used as a bump stop the force is straight up against the rubber, the spring is contacting it at an angle so you are stressing the rubber-metal bond instead of just compressing the rubber.
Old Apr 29, 2009 | 09:52 PM
surveyguy's Avatar
surveyguy
sure cleared off today in western oregon Chris, how are things down there? staying away from the pig flu?
Old Apr 29, 2009 | 11:59 PM
IHbase's Avatar
IHbase
Great- now you have totally defeated the engineering that went into you truck.
1) you put a level kit in it - so it looks like a Vega with a horse in the trunk each time you actually use your truck like a truck.
2) you loaded it, but not up to capacity
3) you decided that the overloads should be touching eventhough you are not overloaded
4) you engaged the overload springs earlier than they were designed to engage.
Brilliant.
Old Apr 30, 2009 | 06:26 AM
F350-6's Avatar
F350-6
The rain is supposed to clear out Friday, but come back on Saturday. They closed the school district in the next town over (Cleburne) yesterday for swine flu, so we'll have to wait and see on that part.
Brilliant.
I'm not quite sure I agree with you here. First, he did not put a leveling kit on his truck. He has Timbren support springs in the rear, and has extended the bump stops to engage earlier. This is done to prevent the truck from squatting in the rear. Has nothing at all to do with the front end.
Next, the purpose of overloads is to provide additional support when loaded without sacrificing ride quality when empty. Worst case all he's done is stiffen up the ride some. You could just as easily swap the springs for a stiffer set, but that would cause a rougher ride when empty.
Third. Contact with the overloads also provides additional sway control, so this mod actually will improve handling. I didn't realize the amount of sway control the overloads provided until I installed my air bags and no longer had my truck sag far enough to touch the overloads.
Do your experiences differ from this, or are you just assuming Ford designed it right to begin with and no one should mess with it?
Old Apr 30, 2009 | 06:47 AM
aldridgec's Avatar
aldridgec
Ford didn't design it right to begin with, at least not in all years. I've seen different years the overloads at different heights. My truck has been severely overloaded and the springs did nothing to assist. They are too far away from the bump stops. In the camper and RV world this is a constant hot topic with many mods and aftermarket products to address the issue. Even with air bags, many still modify the overload perches to contact sooner because it assists with sway control too. I'm not very pleased with the spring design on my truck either in the back. It squats way too easily.
Old Apr 30, 2009 | 05:07 PM
bucci's Avatar
bucci
IHbase brought out some good points, but I must say I took it as sarcasm. Why not post them in a respectable manner so surveyguy and everyone else can discuss them?
As F350-6 said, it is a hot topic. Let's discuss it and come up with ideas that can help everyone.
Someone earlier mentioned the supersway stops by superspring. Has anyone tried those or know of anyone? I asked superspring about them and they are only for sway control and do not help with payload. They also only come in one height of 2-3/4".
Old Apr 30, 2009 | 08:26 PM
  #28
F350-6's Avatar
F350-6
Thank you for this. I've been trying to get dimensions on them to get an idea of how to do my own (similar to what's pictured above), but have not had any luck finding the dimensions.
Old Apr 30, 2009 | 08:55 PM
  #29
surveyguy's Avatar
surveyguy
yeah, i just decided not to respond to the seemingly-vicious comments, i do really appreciate everyone's views, heck, i feel i have some pretty good ideas and views myself, that's why we're here, right? To learn from each other? I mean heck, if they don't like what i bring here, then they don't have to "rep" me. Thanks to everyone!
Old May 1, 2009 | 05:20 AM
  #30
bucci's Avatar
bucci
You're welcome!
