Intake system help
Old Apr 27, 2009 | 11:06 PM
911brandon's Avatar
911brandon
hey guys, isnt that air sucking in hot engine air. Don't you want a cold air intake.
Old Apr 27, 2009 | 11:09 PM
911brandon's Avatar
911brandon
I put a Volant cold air intake in mine and really like it. Search it and see what you think.
Old Apr 28, 2009 | 05:12 AM
King0581's Avatar
King0581
I dont know as that I woulda opened that can of worms. Ha Ha!
Old Apr 28, 2009 | 06:40 AM
spdmpo's Avatar
spdmpo
Congratulations! You figured it out on your own.
Old Apr 28, 2009 | 07:00 AM
Izzy351's Avatar
Izzy351
Yes, at idle or very slow speeds. But is has been proven over & over (despite theories, formulas, and speculation) that it makes little if any difference in practice for most folks.
From what I've read, that's a great intake...
Old Apr 28, 2009 | 08:33 AM
brian42's Avatar
brian42
Veteran: Navy
Anything that replaces the stock air box is an improvement, since it doesn't seal well (even with an aftermarket filter in there).
Sure the 6637 mod sucks in engine compartment air, but the zoodad mod helps with that.
I would love to write checks all day and order everything I wanted for my rig, but unfortunately my bank account isn't bottomless (more like the shallow end of the kiddie pool these days). I can either spend $200-$500 for the AIS, aFe, Volant or S&B and get an intake, or I can spend $50, get a 6637 and do the zoodad for free. Hhhmmm...which do you think my wife gave the green light for...? I'll take anything I can get over the stock box! Plus that leaves me a little extra to put aside for those gages I've been saving up for...
Old Apr 28, 2009 | 08:35 AM
03_PSD's Avatar
03_PSD
this reminds me, i need to do this free mod, zoodad!!
Old Apr 28, 2009 | 08:55 AM
superduty4x4's Avatar
superduty4x4
If you're worried about sucking in warm air from under the hood, build a cold air box for your 6637 as many here have done.
Old Apr 28, 2009 | 12:52 PM
ernesteugene's Avatar
ernesteugene
Originally Posted by F250TruckR
...ive heard the aFe intake system is by far the best and ive done my research and read all the facts and it sounds like it is...
I'd sure like to hear your definition for "the best" and a summary of you research that indicates the aFe is better than for example the S&B unit.
Old Apr 28, 2009 | 01:21 PM
ernesteugene
Originally Posted by Izzy351
...Yes, at idle or very slow speeds. But is has been proven over & over (despite theories, formulas, and speculation) that it makes little if any difference in practice for most folks...
And to think you're the one who once posted a picture of me beating a poor dead horse! You won't even accept the "measurements" reported on the Dale Isley Tymar Performance web site which I discussed along with a number of other "measurements" in post #161 here... https://www.ford-trucks.com/forums/8...estion-11.html ...and I guess you must think Ford really screwed up big time by designing a radiator fan clutch which "measures" when the engine compartment air temperature increases to above 205 F as is discussed in post #168!
Originally Posted by ernesteugene
...If you assume that there's 5.28 ft^3 of free air space available in a 7.3L engine compartment from the hood (closed of course) down to the bottom of the engine then this 5.28 ft^3 engine compartment air space implies that an "open element" AF which is sucking in a 528 CFM airflow to supply the engine sucks all of the available air out of the engine compartment 100 times each minute! Where does all of the needed replacement air come from?
It comes from the ambient air but thanks to the Ford design 100% of the ambient replacement air is forced to flow through a 140 F A/C condenser, then if you're at a sustained 18 psi boost it's forced to flow through a 160 F IC, and finally it's forced flow through a 190 F radiator and then it picks up even more heat from the exhaust manifolds etc.. and then it flows directly into your "open element" AF!
And yet people continue to claim that the air flowing into their "open element" AF is only 2 F or 20 F or whatever unbelievable (for me anyway) low number of "F" hotter than the ambient air is!
Now consider an alternative. if you're going 60 MPH=5,280 ft/min a "cold air intake" only needs to have a 0.1 ft^2 (3.8"x3.8") opening in order to supply an AF with a 528 CFM flow of "outside RAM ambient air" which no matter how you want to cut it is much cooler than the ambient air that's forced to flow through the A/C condenser, the IC, and the radiator!
In addition to being much cooler the "outside RAM ambient air" due to its RAM air effect also supplies the "cold air box" with "pressurized" air which reduces the restriction of the "cold air element" by 2" H2O.
This means there's two different ways by which a "cold air intake" reduces the workload on your turbo relative to the workload that's required for an "open element" AF... 1) the cooler air increases the air density at the compressor wheel and 2) the higher pressure air increases the air density at the compressor wheel.
Since MAF={(AD)(CFM)} lb/min an increased AD=Air Density lb/ft^3 means that it takes less CFM to provide a given MAF to the engine and less CFM means the compressor wheel rpm is lower for the same MAF. Conversely an increased AD means that more MAF can be provided at a given CFM...
Old Apr 28, 2009 | 01:28 PM
makomaker's Avatar
makomaker
I predict 7 pages. Subscribing.
Old Apr 28, 2009 | 01:37 PM
spdmpo's Avatar
spdmpo
Instead of laying a temp sensor or thermometer near the filter and out in the open under the hood, has anyone probed the air intake tube between the filter and the turbo inlet? I'd love to see those measurements between a filter on a stick and a factory or AIS intake; or even an enclosed filter on a stick for that matter.
Damn, I might just have to see if I can borrow or steal a temp probe and do it myself 'cause I'm curious. Not sure what to do with the hole in the intake tube afterward though.
Old Apr 28, 2009 | 02:35 PM
  #28
superduty4x4
Send Joe (CSIPSD) a PM as I believe he has done some testing similar to that.
Old Apr 28, 2009 | 03:32 PM
  #29
Pocket's Avatar
Pocket
Well since the same old argument keeps coming up again and again... here is my last contribution to this thread:
Old Apr 28, 2009 | 03:49 PM
  #30
brandon_oma#692's Avatar
brandon_oma#692
I love that picture!!!!!
