Just Ordered AeroForce Gauges!!!!!!!
Old Apr 23, 2009 | 06:54 PM
megawatt00's Avatar
megawatt00
Congrats Nolan I'll be looking forward to hearing about the install and your feedback on the guages themselves.
Old Apr 23, 2009 | 06:59 PM
jeff7825's Avatar
jeff7825
Originally Posted by just another truck
i went to the advertisement, this thing can do a lot!! But it mentions a lot of things our truck dont look at.. so I was asking , kind of, what can be added to this gauge so as you can see everything it mentions.. I might need to relook at the advertisement, but now that I have, it appears to be like a functional scan tool.. Kind of cool.. but then.. do I wan tto see what the engine os doing, and then what my engine thinks its doing by having both sets..and for me.. I already have sensory overload watching the gauges and the smoke at the same time
I don't think that it will monitor everything as advertised on our trucks, but most things. You have to add sensors for things like fuel pressure and coolant temp. I think that it has two inputs on the gauge to add these additional sensors. I plan on getting one one day to fill the void in my three gauge under the dash pod.
4inchlovin's Avatar
4inchlovin
I just looked and it says it monitors boost also and Coolant temp.
Old Apr 23, 2009 | 07:04 PM
jeff7825's Avatar
jeff7825
There was some thread the other day talking about if you have an automatic, it won't read coolant temp.
Old Apr 23, 2009 | 08:32 PM
4inchlovin's Avatar
4inchlovin
Really... thats weird... Any ideas what that thread was???
Old Apr 23, 2009 | 08:37 PM
just another truck's Avatar
just another truck
I didnt read all the way through it, but I believe it was Scotts thread, he to is looking at these.. they are very cool for sure.. I am looking forward to hearing about them..
Old Apr 23, 2009 | 09:04 PM
Izzy351's Avatar
Izzy351
Only the manuals monitor coolant temp. That's one of the things I've been wanting to add -- that and a real oil pressure gauge, so that's why I'm adding those two. It will read a ton of stuff, for sure. I did email Joey at Terminator and he confirmed that with an auto, you have to add sensors to monitor coolant temp & oil pressure (well, oil pressure with either trans). I would do fuel pressure, but I'm doing the "BDrummonds FP Gauge Pod Mod", so I'll have a dedicated gauge for that...
Old Apr 23, 2009 | 09:11 PM
4inchlovin's Avatar
4inchlovin
i think one of these would be a great addition to anyones set up for sure.
Old Apr 24, 2009 | 12:50 AM
duck fan's Avatar
duck fan
Because racetruck
Nolan, why do I have this strange feeling you are going to be calling me.... I have a drill bit and tap for the EGT so let me know when you are ready to get your install on.
Old Apr 24, 2009 | 01:40 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
(giggles because all i have to do is plug it in)
So, do you have to cut the plug off one of the gauges and splice them together to get both gauges reading off the single data connector port? Will the voltage variations across the splices change the readings if you do?
Old Apr 24, 2009 | 10:00 AM
VoodooRacer's Avatar
VoodooRacer
i think id you order the two gauge setup they come pre-wired to just plug in so you dont have to splice in. If you buy one and get a second later then you may have to splice.
Correct me if im wrong Nolan.
How accurate is the pyro and trans temp gauge? Cause i would love to have a plug in play system like this if it was as accurate on those two things as an analog.
I have a mechanical boost gauge because i have heard the PCM will cut out at 22LBS if you get a chip and what-not.
Old Apr 24, 2009 | 10:07 AM
megawatt00's Avatar
megawatt00
If the PCM sees an overboost from the MAP sensor it will defuel the truck. This means that it is not limited from seeing over 22 psi it just means that it defuels at that point.
Old Apr 24, 2009 | 10:10 AM
  #28
VoodooRacer
ok i got ya so what ur saying is it will read boost higher than 22? Will the dp-tuner chip correct the de-fueling problem once it reaches this psi.
Old Apr 24, 2009 | 10:42 AM
  #29
just another truck
Scott, Normally splicing into a sensor, suprisingly, does not effect the reading.. We normally have to do a calibration to many of our sensors and gauges, we do so just by piggybacking,..
Old Apr 24, 2009 | 10:51 AM
  #30
soutthpaw's Avatar
soutthpaw
Well I priced out what it would cost to get the PSD version with the Pyrometer and th came to almost $600
I just bought a triple gauge setup from Clay at Riffraff diesel and got my AE ford enhanced software total about $625
You can do a whole lot more with AE software than you can with the gauge you are talking about here...
To me it just seems a better deal to go with traditional gauges and a good Scan tool software...
