coolant question
Old Apr 23, 2009 | 12:30 PM
phillips91's Avatar
phillips91
coolant question
anyone know right off how much coolant our trucks hold? im flushing the system this weekend and all my books just say "fill till full."
Old Apr 23, 2009 | 01:28 PM
250turbo's Avatar
250turbo
obs hold 23 qts.
Old Apr 23, 2009 | 01:45 PM
phillips91's Avatar
phillips91
i was thinking 25 off the top of my head, but i think thats for my SD. thanks for the info.
Old Apr 23, 2009 | 02:01 PM
powrstrkr's Avatar
powrstrkr
I think mine said 22qt and that's how much it took last year when I changed it. But I may not have gotten it all out. Don't forget to use the NAPAKool additive to prevent cavitation holes. And get some test strips also while you're there.
Old Apr 23, 2009 | 02:16 PM
phillips91's Avatar
phillips91
i was looking at this brand called final charge and it says it already has the additives in it. anyone have any luck with that brand?
Old Apr 23, 2009 | 02:17 PM
powrstrkr's Avatar
powrstrkr
Never heard of it but I would use a test strip on it anyway.
Old Apr 23, 2009 | 02:20 PM
phillips91's Avatar
phillips91
im heading over to napa here in a few minutes, ill check and see if they have any.
Old Apr 25, 2009 | 09:22 AM
DRRXR's Avatar
DRRXR
Coolant
I have been running this in my truck for over a year. Any thoughts on this?
http://www.alexisoil.com/pdf/TexELC.pdf
Old Apr 26, 2009 | 05:58 AM
ckal704's Avatar
ckal704
well, the spec sheet makes it sound like it will do the job. I honestly don't know anything about it other than I'd like to switch to extended life coolant and just have to top it off once or twice a year and not fool with the addititive.
Old Apr 26, 2009 | 06:55 AM
Supercab's Avatar
Supercab
Wink
The FINAL CHARGE available at WalMart is what alot of over on the '99-'03 PSD forum use, its pre-mixed, and redily available at Wally's just like the rotella oil, just be sure & flush out as much of the old stuff that you can first.
Also consider a coolant filter setup from Dieselsite-I got one for my '99 and its great!!
