E40d/4R100
Old Apr 23, 2009 | 06:33 AM
f350idi's Avatar
f350idi
Question E40d/4R100
Hi,
Can anyone tell me if a 4r100 diesel trans will work behind a efi 460 BB which has a E40d trans. both trans have late version solenoid packs. I know the speed sensors cant be used and the lock up clutch control in the in two pumps are diferrent, E40d on /off and the 4r100 modulated.
Has any one done this conversion?
Cheers
F350idi
Old Apr 23, 2009 | 07:07 AM
Lazy K's Avatar
Lazy K
Can`t answer your question but I think the bolt patterns are different in the two engines.
Old Apr 23, 2009 | 07:19 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
A diesel trans will have a bolt pattern that does not match the 460.
Old Apr 23, 2009 | 07:27 AM
f350idi's Avatar
f350idi
Red face E40d/ 4/r100
Thanks for your reply guys, I have the 460 e40d and 7.3 4r100 trans stripped down in my shop , I will check the bolt paterns tomorrow. looks like I may hve to rethink this one.
Cheers
F350idi
Old Apr 23, 2009 | 12:15 PM
71cc's Avatar
71cc
the e4od diesel cases have no provision for a starter.The starter mounts to the adapter plate.
Old Apr 24, 2009 | 04:03 AM
f350idi's Avatar
f350idi
Smile E40d/ 4/r100
Thanks guys , both cases are different at the bell housings. There must be only 3 cases in the E40d. Big block, small block and diesel with diesel being the same as 4r100 minus the PTO take off and the turbine and output shaft speed sensor holes. Does that sound about right?
Cheers f350idi
Old Apr 24, 2009 | 07:54 AM
Mark Kovalsky
It's about right. The only part I'd correct is that not all 4R100s have the PTO provision.
Chippenwhales
15
Nov 11, 2025 10:18 PM
Cajundawgs
Oct 26, 2012 07:17 PM
Bear1971
Mar 17, 2003 07:53 AM
Monsta
Apr 11, 2002 06:09 PM
