mud flap / guards
mud flap / guards
Hi All,
Looking for input on "Sturdy" mud guards. I have a 02 f250, I am just getting it repainted as all of the old flaps got torn off from snow banks and such. And as a result, paint got pulled off. I do plow with the truck, so that is the reason. But are there any out there that will stay on a bit better. I will not be hitting banks at full speed but things happen and I dont want to worry.
Thanks,
Ron
Thanks,
Ron
I put semi mud flaps on mine, They rpotect it well. Generic flaps from a truck shop are $7.00 each. Trim And fit. On the rear ones becarefull, you might want to use a chain if mudding or backing over uneven ground. I also put in brackets off the frame so it doesnt hang off the body panels
I picked up a set on ebay that have a stainless steel plate on the bottom with f-250 or 350 cut out of the plates, they are heavy duty and were not too pricey. I just put them on with some self tapping sheet metal screws. Just do a search for f-250 mud flaps on e-bay and they probably have hundreds to choose from.
on
I picked up a pair in Ebay and attached them with screws and fender washers. Now that I have done that I think the best idea is to go 1 step further and get some heavy truck flap material and cut them to a custom size and then use my own holes and fender washers. Trying to get a flap with the right holes and the right flap is a waste of time. ............Custom!!!!!!!!
jrahn
1997-2006 Expedition & Navigator
10-27-2002 09:50 PM
