Fellas
I have a 94 Aero, the power window switch does not work for either the the drivers and pass. windows. I have changes the switch. Im thinking in maybe the wiring. I have the wiring scmatic and there is a LB/Bl wire that has power to both switchs that maybe cut. Is the main wiring harness hard wired, or can you unplug it?
Any other suggestion?. Yes the motors work.
Fellas
Check the harness where it enters the door hinge panel where the rubber boot is. They crack there over time due to fatigue from open/closing the door.
Thanks
Checked the wiring just under the damn tape in the door. The wire was just split alil, just to short out. Anyone looking for a new window switch hahah
