Flush or Drain Trans fluid?
Old Nov 20, 2002 | 02:53 PM
mikew262's Avatar
mikew262
What is better, flushing the fluid or just draining it? One mechanic told me never to flush it, because it just causes the chucks of metal and other things to circulate throught the entire system and possibly stick to the interior components.
Old Nov 20, 2002 | 06:44 PM
AggiePSD's Avatar
AggiePSD
I would say that depends on the mileage on the transmission and how often it has been serviced. If it has 100,000 mi. and has never been touched, I would say you might just be better off leaving it alone, although you can count on a rebuild. If it has at least been drained regularly or within the last 25 - 50,000 I would say you are ok. I would say the risk is worth it considering the vast improvement in life expectancy if flushed. Just my opinion.
Old Nov 21, 2002 | 01:43 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
[updated:LAST EDITED ON 21-Nov-02 AT 02:44 AM (EST)]Go to the Tech Articles portion of this site. I wrote an article on how to do a full fluid exchange.
Most flushes are really just a fluid exchange. That's OK in my book, you really don't want to use a flush chemical. It can't dislodge anything more than regular operation will, because the fluid flows the same way during the exchange that it does during normal operation.
I think the full exchange is a little bit better than draining hte pan and torque converter. If you only drain the pan the exchange is MUCH better.
Old Nov 21, 2002 | 03:00 PM
76_F150_390's Avatar
76_F150_390
beeser
Sep 30, 2013 03:37 PM
AJB201
Jul 6, 2011 01:54 PM
Patatoe1
1997 - 2003 F150
Mar 15, 2006 09:18 PM
neilc88
Aug 17, 2005 11:20 PM
gbeach
16
Jan 12, 2004 07:57 AM
