headlight mod. done!!!
Old Apr 20, 2009 | 01:58 AM
rupejosh's Avatar
rupejosh
Originally Posted by starmilt
A couple years ago the KW dealer in whitehorse started installing hids for the 4 headlight system in kws at 1200 I still run my landing lights.
dang you could almost cook hotdogs off those
Old Apr 20, 2009 | 02:15 AM
starmilt's Avatar
starmilt
HIDs dont put out near the heat as conventional lights.
Old Apr 20, 2009 | 02:36 AM
rupejosh's Avatar
rupejosh
i need to mount a couple 3 big lights on my headache rack 2 to face forward and one facing backward so i can accidently turn it on when someone tailgates me.
Old Apr 20, 2009 | 02:50 AM
starmilt's Avatar
starmilt
I've got 4 160 watt ac landing lights backwards on my W9.
Old Apr 20, 2009 | 03:08 AM
rupejosh's Avatar
rupejosh
how bad does that fry people behind you?lol
Old Apr 20, 2009 | 03:16 AM
starmilt's Avatar
starmilt
So far I havn't fried anybody but I could light them up if I wanted to. It makes it nice at night I had a guy trying to park in a dark spot one night he came thanked me when he got parked and wanted to look at my setup.
Old Apr 20, 2009 | 02:02 PM
rupejosh's Avatar
rupejosh
it would be nice for parking at night
Old Apr 20, 2009 | 05:52 PM
Mat J's Avatar
Mat J
can you link the diagram i want to do this
what gauge wire do you upgrade to?
Old Apr 20, 2009 | 07:25 PM
Franklin2's Avatar
Franklin2
Be aware the relay modification will lessen the life of the bulbs a little bit.
Old Apr 20, 2009 | 07:40 PM
starmilt's Avatar
starmilt
I read that several years ago but have not noticed it so it wont be shortened very much.
I would way rather change a headlight than the switch and only one headlight goes out at a time.
Old Apr 20, 2009 | 10:16 PM
rupejosh's Avatar
rupejosh
https://www.ford-trucks.com/article/...r_Brights.html
check out my other thread titled "i think i fried something"
https://www.ford-trucks.com/forums/8...something.html
Old Apr 21, 2009 | 02:52 PM
99SevenPoint3's Avatar
99SevenPoint3
very interseting i had always thought that my lights werent gettin sufficent power ... ima try this mod with some nice sylvannias see if it works...better then what i have now..
Old Apr 22, 2009 | 10:08 PM
  #28
Dave Sponaugle's Avatar
Dave Sponaugle
There are two different ways to do this mod.
One just uses larger AWG wire from the battery positive post and the other uses larger AWG wire attached directly to the alternator output terminal.
I ran mine from the passenger side battery positive terminal with 10 AWG wire and am very happy with Silvania Silverstar Ultra bulbs.
I did have to switch to composite headlamps with the jewel pattern reflector which also give much better light control to use the Silverstars in my 86, but I am extremely happy with the mod.
The sharp beam cutoff the jeweled lights give keep the light out of oncoming traffic faces and rear view mirrors of people I am following.
The extra brightness probably doubled how far I can see when the high beams are on.
And getting the amp load off the headlight switch and the main power feed into the cab helped everything else out as well.
Old Jun 11, 2009 | 06:07 PM
  #29
99SevenPoint3
ok i need some help ... i "think" i did exactly as the diagram showed but when i hook up the 85 side it didnt come on so i jumped it directly off the battery to the 85 side and it turned on so what gives?
Old Jun 11, 2009 | 08:17 PM
  #30
Mat J's Avatar
Mat J
sounds like you arnt getting power from on of the headlights to turn on the relay. double check those connections.
