excursion will not start
Old Apr 19, 2009 | 04:23 PM
drod2001x's Avatar
drod2001x
Hello all i have a 2001 excursion and it was parked in my garage,I started it and drove it out of the garage and then parked it in the drive way.it stayed like that for a day and a half and now it will not start,it has a 1\4 tank of gas it is at a slight slope.I dont drive it much it will spin over just wont start.checked fuses tried fuel reset,still no luck,it did this once before and i pushed the reset switch and it fixed the problem.tried a jumper wire on the reset harness to by pass switch no luck
Old Apr 19, 2009 | 04:54 PM
cbradford's Avatar
cbradford
Is the fuel pump running? When you turn the key
Old Apr 19, 2009 | 05:20 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Is this a Power Stroke Diesel or a gas engine?
Old Apr 19, 2009 | 06:03 PM
cbradford's Avatar
cbradford
Good question, I'm thinking gas due to the mention of 1/4 tank of gas and reset switch.
Old Apr 19, 2009 | 10:16 PM
drod2001x's Avatar
drod2001x
broke excursion
it is a gas v8 I could never hear the fuel pump before i have tried to listen 4 it but i cant tell
Old Apr 19, 2009 | 10:30 PM
drod2001x's Avatar
drod2001x
gas do you think it could be the fuel pump
Old Apr 21, 2009 | 07:45 PM
cbradford's Avatar
cbradford
You could check the fuel pressure, on the fuel rail there is a plastic cap when removed exposes a schrader valve ( like a tire valve ) and attach a pressure gauge turn the key to the on position and see if you have fuel pressure ( about 40psi) this will tell you if the fuel pump is running, or you can do the same thing without the gauge and just push the valve in with small screwdriver and gas should shoot out at you this will a least tell you you have pressure but not how much.
Old Apr 21, 2009 | 08:45 PM
drod2001x's Avatar
drod2001x
broke excursion
thank u I actually put the x in neutral and let it roll back to a almost level position,and let it sit for almost 10 minutes,and kind of rocked it back and forth,push the reset button again and it crunk right up?I checked the gauge and i actually had 77 miles to empty,do u think that it might have been out of gas because of the slope it was on?
Old Apr 21, 2009 | 08:53 PM
VaSheriff's Avatar
VaSheriff
Originally Posted by drod2001x
....do u think that it might have been out of gas because of the slope it was on?
I think there's a better than average chance that was your problem.
Keep the tank at least half full at all times and see if it happens again.
Old Apr 21, 2009 | 09:07 PM
drod2001x's Avatar
drod2001x
Sounds like a great idea i really appreciate all your help thanks
Old Apr 22, 2009 | 12:32 AM
VodkaMan's Avatar
VodkaMan
If you can fill your tank see how many gallons it takes.
Bkadds
1997 - 2003 F150
18
Feb 13, 2015 02:45 PM
gerrell3345
1997 - 2003 F150
May 26, 2014 09:17 PM
xmontex4
Oct 28, 2013 11:48 PM
GregN
Nov 7, 2010 05:36 PM
Jeepmb
Nov 2, 2007 06:49 PM
