Darn ABS light
Old Apr 17, 2009 | 10:29 PM
tykateexcursion's Avatar
tykateexcursion
Darn ABS light
help i have a tempermental ABS light that comes on when i put the vehicle in gear.. once in a while i get lucky it stays off then the anti lock kicks in on dry pavement then the ABS lights up. Any opinions greatly appreciated. Could It be a rear sensor?? befor I go to the shop!!!!
2000 Expedition 2wd V10 LTD
Old Apr 18, 2009 | 10:15 AM
Bluewater's Avatar
Bluewater
Try the cheap repair first
Had a similar issue. Eventually I also got a check engine light and the O/D light on the column shift handle would blink. Went to Ford and they tried to jack me for 3 diagnostics charges because they said I had 3 issues (lights) on. Once they realized I wouldn't play, they did the diagnostics and said the ABS module was fried, quoted over $1K to fix. Bull....
Long story shot, thanks to this forum, I bought a speed sensor, unplugged the battery, installed the sensor (took maybe 5 minutes) and my Ex has been runnin strong ever since.
p.s. I tested the ABS on the first snow and it works perfect. I posted the diagnostic codes the dealer gave me in an earlier post...
Old Apr 18, 2009 | 03:51 PM
topgun35's Avatar
topgun35
Bluewater i have a similar issue my abs light is on and my speedo does not work bounces once in a while is that the same speed sensor thats located on the rear diff on top i think its called a VSS not sure was planning on changing it.
thank you Tony
Old Apr 19, 2009 | 09:38 AM
tykateexcursion
Well I replaced the sensor and still have the ABS light on. I guess i will take it in. We have a shop in the area that has all the computers without the big dealers price. In fact the big dealers send cars to this shop when they can not figure the problem out. Thanks for the help
Old Apr 21, 2009 | 04:57 AM
Move over I'm coming's Avatar
I believe Autozone will run the scan for free. Tell them to clear codes once you jot them down so repeating codes can be fixed.
Old Apr 21, 2009 | 09:11 PM
tykateexcursion
I went to auto zone No code found. The scanner they were using must not had the ABS software version. I have good hydralic brakes and been to the brake shop and the rotors and pads are good. Pads front and back 85% and the rotors were within spec, nbot warped.
Old Apr 22, 2009 | 05:22 AM
If ABS light is on there should be a sensor out. It should set a code thus the warning light. Pads & rotors won't set light.
Find someone with a better scanner. Good luck.
